Home Forums Product Discussion & Questions BeoLab Bl3500 + converter 1611
  • #51564
    silpou
    The goal is to use the BL3500 as a standalone. The non-Beo audio goes into the 1611.
    Just connected a BL3500 with a 1611 with a ML cable.
    BL3500 can start with any source key. But stay no on and canot adjust the volume.
    Is something wrong or is this idea no possible ?
    #51565
    Guy
    That sounds like the BL3500 is not getting a ‘valid’ input.
    Try pressing MENU 09 GO and checking that ML is switched on, as described in this post by madskp: https://forum.beoworld.org/forums/topic/beolab-3500-does-not-work-in-masterlink/#post-22054
    PS:  I think I recognise your username from the archived forum, but if you are indeed new here then welcome to Beowrold!!
    silpou
    Thanks Guy,
    With a new cable it works ! But the sound is coming only when an Video source is selected.
    No sound with radio or AAUX or ATAPE2 or …
    PS Yes I was on the old forum. I’m back!!! Thanks
    #51567
    Guy
    Welcome back!
    Yes that’s how it will perform with a standard DIN input (pins 3 and 5) to the BL1611’s AAL socket – only VIDEO source selection will activate the input.
    Have a look at this post (and thread) and you will see that the BL1611 can accept an AUDIO input but only if connected to pins 1 and 4 of the DIN AAL input: https://forum.beoworld.org/forums/topic/beolab-3500-and-1611-converter-settings/page/4/#post-14017
    It’s a very useful solution for a double input to BL3500 etc.
    silpou
    Very interesting post!
    Perfect thanks Guy !
