Home › Forums › Product Discussion & Questions › BeoLab › BL3 on table stands pls help
- This topic has 4 replies, 4 voices, and was last updated 3 years, 9 months ago by
Millemis.
2 July 2022 at 04:04 #35968
libor
BRONZE MemberHi Beofans,
would somebody with BL3’s on table stands be so kind and tell me the total height? I have quite a limited space under cabinet and would like to be sure that my BL3’s will fit after I buy table stands, thanks.
Oh and how thick is the base plate? Is it more then 6 mm?
2 July 2022 at 18:35 #35969 TignumGOLD MemberHi libor, welcome!
I do not have these speakers but found a pdf catalogue that says they are 32cm high:
I trust they will need a bit of space around them to work correctly, that will for sure be written in the manual.
At the B&O website you can download an ‘.obj’ file of the BeoLab 3 that might give you the exact height of the base (using a CAD system).
Good luck, would be nice to see a photograph of the result in the ‘Flash your B&O’ thread!
Regards,
Johan
2 July 2022 at 18:39 #35970 TignumGOLD MemberThe .obj file shows like this in my standard mac preview app (I cannot measure it there, sorry).
3 July 2022 at 12:15 #35971 Rolf2GOLD MemberHi libor,
I can confirm a total height of 32 cm as Johan has displayed. I have the BL 3 on table stands in our bookshelf. In my case, I was able to build the bookshelf around the speakers :-).
The round base plate is 6 mm thick and it stands on rubber feet which take appr. 0,5 – 1 mm in height (I cannot measure more accurate, sorry).
I hope it helps.
Kind regards,
Rolf
Favourite Product: BeoSystem 4500
4 July 2022 at 14:03 #35972 MillemisBRONZE MemberHi libor.
If you have limited space/height there, why not go for the rubber stands instead?
Would also make it easier to point the speakers a bit up or down depending on what you’d need.
Please do not move these speakers too far back from the edge of the shelf/cabinet – the Acoustic Lenses need space for spreading the sound.
