Home › Forums › Product Discussion & Questions › BeoGram › BG 4002 new restoration Start
- This topic has 6 replies, 3 voices, and was last updated 2 years, 1 month ago by
george a.
21 November 2023 at 01:55 #50653
george a
BRONZE MemberHi All
Just starting a BG 4002 5721 restoration
at turn on the motor for the sliding carriage starts and moves it to extreme right (stopped position)
The carriage motor just keeps on running try to move carriage – (which cant do any further)
Looking for suggestions to possible cause..
The lamp for the carriage position sensor is blown…(the one that shines through the plastic ruler thing)– Could this be the problem? -I intend to replace with LED
The Lamp for tone arm position is also blown and will replace with LED- this is the lamp to help tonearm follow grooves..
Need to also find STL file to 3Dprint lamp holder
Transformer , power cap(4000uF ) and solenoid all appear ok
Speed control lamps also blown
No items on PCB placed yet.
Dont know condition of main motor yet.
Can anybody poss help with Carriage motor problem?
Many thanks in advance
George
21 November 2023 at 02:20 #50654auric
BRONZE Member22 November 2023 at 03:37 #50655george a
BRONZE Memberthanks Auric
Will have a look through– lots of good stuff there..
After further investigation I ma suspecting that a total recap of the control board may be required…..
Cheers and thanks
George
23 November 2023 at 13:29 #50656george a
BRONZE MemberJust to add further inof The carriage motor has a constant 18v applied to it when the turntable is plugged into the wall and power is available..
Any ideas
TIA
George
23 November 2023 at 14:55 #50657george a
BRONZE MemberAnd further discovery..
my BG4002 5521 seems to have an output board from a BG4004 5526…? underneath control switch panel
I wonder what effect this would have..???
23 November 2023 at 15:14 #50658Dillen
ModeratorDoes it say Beogram 4002 or 4004 on the operating panel?
Does the panel have a connector to the “output” board?Martin
24 November 2023 at 08:41 #50659george a
BRONZE MemberHi All
i pulled out the pcb’s and sprayed all connections / pins etc with contact cleaner
-SHE LIVES!!
All required now (hopefully ) is a general clean and following issues
a) speed indicator lamp relay etc- 33 not lighting up 45 (45 is lighting up)- both globes measure ok..
b) adjust Arm position sensor so grooves are tracked more accurately – at this time the pickup arm needs to move excessive distance for carriage motor to activate..
c) General lube
d) Lid repair and polish (big job- may look at making a new one in clear acrylic
e)replace cartridge
some measure of relief now
Thanks to those who have offered comments
George
