Home › Forums › Product Discussion & Questions › BeoGram › Bg 4000 tonearm behavior
- This topic has 5 replies, 3 voices, and was last updated 3 years, 4 months ago by
bulldog123.
23 November 2022 at 06:26 #40997
bulldog123
BRONZE MemberOn an otherwise fully functional Bg 4000 5215 I am getting the following behaviors:-
1) when pressing the ^ button the tonearm does not stay up once the ^ button is released – it just drops as if the down button had been pressed. Same behavior on < and > buttons – is this a keypad problem or should I be looking elsewhere?
2) from time to time the tone arm drops suddenly instead of the normal smooth drop that is expected. This is not a persistent problem.
Any thoughts and guidance greatly appreciated.
25 November 2022 at 09:15 #40998 spassmakerBRONZE MemberHi
Cold be a keypad problem, regarding to the SM the \/ button is normaly closed and the /\ button is normaly open.
So as there is a bad contact at the \/ button the tonearm will only stay up as long as you push any other button.
Cleaning the contacts is recommended, look here for further information:
https://beolover.blogspot.com/2017/10/beogram-4004-type-5526-keypad-contact.html
Kind regards
Christian
26 November 2022 at 17:32 #40999bulldog123
BRONZE MemberThanks Spassmaker I will look at that.
27 November 2022 at 12:00 #41000hcraig244
SILVER MemberJust spotted this post justin, picked up a chest infection from soewhere ;¬(
The tone arm dropping sharply sounds like not enough dampoing, try winding the srew in very slightly…..and I would check out the down switch contact…..if its playing up the tone arm will dot stay up when ^ is pressed
27 November 2022 at 12:16 #41001bulldog123
BRONZE MemberGreat Craig. Thank you. I hope you make a speedy recovery.
27 November 2022 at 21:09 #41002bulldog123
BRONZE MemberFixed. Thank you Craig and Christian. The down switch contact terminal was oxidized and bent – after cleaning and straightening it works a charm. Tone arm is dropping smoothly now. Sweet sounds are emanating from the deck and its owner. Thanks again.
