Home › Forums › Product Discussion & Questions › BeoVox › BeoVox 3000/4500: pictures of the interior?
- This topic has 6 replies, 3 voices, and was last updated 2 years, 1 month ago by
lausvi.
15 May 2023 at 10:40 #46632
KolfMAKER
BRONZE MemberDoes anyone have pictures of the BeoVox 3000 or 4500 interior?
So with the front panels removed?
15 May 2023 at 17:16 #46633 lausvi
SILVER MemberIf you mean front panel (cloth) removed, there will be only the two speaker elements (second picture here) visible.
If you mean back cover removed, here are some pictures from when I recapped mine. These are Beovox 3000 Type 6716.
15 May 2023 at 19:33 #46634 KolfMAKER
BRONZE MemberThnx very much Lausvi.
you are completely right. I wanted to see the interior. And as I haven’t had my hands on this BeoVox type yet, I wasn’t aware that the back panel had to be removed to get there. So thanks for understanding that.
If I may ask …
In picture 1 and 2, the two pieces of white foam van be seen on the right.
What are the dimensions of both pieces? (W x L x D)
15 May 2023 at 20:27 #46635 lausvi
SILVER MemberNo worries ?
Unfortunately I don’t have access to the speakers now (I sold the BV3000s and upgraded to BL45000s which are the same size but are currently in storage) so I can’t check.
However as the BV3000 specs say the speakers are 45 x 38 x 8cm (W x H x D) one could perhaps approximate the size of the foams form that. I think they had a white fabric on the outside but felt like foam on the insde.
There is also a foam tape -like gasket. It’s the black tape on the first picture and green on the second as I had replaced it. Not sure if totally necessary but the old stuff was crumbling and I had something close-enough at hand to put in there.
Are you trying to make new acoustic foams?
18 May 2023 at 12:51 #46636 KolfMAKER
BRONZE MemberThanks a lot, perfect.
Yes, with the dimensions that are known and your pictures, I can estimate all other dimensions. That will work.
2 March 2024 at 21:27 #46637Psycho Dave
BRONZE MemberI am late to the party, but what did you use for new gasket?
lausvi wrote:
There is also a foam tape -like gasket. It’s the black tape on the first picture and green on the second as I had replaced it. Not sure if totally necessary but the old stuff was crumbling and I had something close-enough at hand to put in there.Location: Sweden
Favourite Product: Beocenter 9500
Signature: Beocenter 9000
Beocenter 9500
Beosystem 2500
Beosystem 4500My B&O Icons:
2 March 2024 at 21:35 #46638 lausvi
SILVER MemberIt was just double-sided foam tape, couple mm. thick. It resembled the original and it felt like it would do the business.
