Home › Forums › Product Discussion & Questions › BeoVision › BeoVison 7-40 sudden death of the display
- This topic has 1 reply, 2 voices, and was last updated 4 years, 4 months ago by
Millemis.
5 May 2022 at 09:39 #34594
TablokaBRONZE MemberFor now 10 years our BeoVision 7-40 worked fine. A few weeks ago during a television broadcast the display went dark and since then the TV itself is dead. The other equipment like the overture and beogram work fine despite the failure. I gave the BeoVision to the B&O dealer for repairing. They changed a lot of modules but without succsess.
It seems that the backlight could be the broken part and therefore the TV is a total loss. That is the statement of the B&O dealer!
Could this be true? Does anybody know how to rapair the TV or where do I have to look for the failure?
5 May 2022 at 15:53 #34595 MillemisBRONZE MemberWhat a pity.
You don’t state which version of the BV7-40 you have – and also not where you are located.
In my experience it is not worth it to bother about repairing these old tv’s.
There are plenty of preused BV7-40’s out there at a very low price.
Swapping out the tv should be fairly easy.
Tip! If you buy it from a dealer, he should be able to upload the PUC codes, that you’d need.
