Home › Forums › Product Discussion & Questions › BeoVision › Beovison 11 – 404 not found error
- This topic has 5 replies, 4 voices, and was last updated 3 years, 10 months ago by
andy_js.
1 July 2022 at 02:17 #35945
splud
BRONZE MemberHi Guys, As below, this error msg just started yesterday on normal terrestrial TV, does anyone know how to disable it?
Tristan
3 July 2022 at 10:47 #35946 HiortGOLD MemberDoes it appear when you use the builtin tuner, “on top” of the TV program you watch? It looks as a message from a web service,
Doubt it has anything to do with the BV11 itself.
4 July 2022 at 01:23 #35947jldmelb
BRONZE MemberI’m getting the same on my Avant, and I know of someone getting it on their V1 and their Avant. Seems to be a universal issue
4 July 2022 at 01:28 #35948jldmelb
BRONZE MemberIt seems to be an issue with the built in Freeview option in the tuner. Instead of the bar coming accross to select Red for catchup tv or green for Freeview I’m getting the 404 message. It’s overlaid over the program.
I’m guessing a software issue?
4 July 2022 at 02:05 #35949splud
BRONZE MemberIt could be that its looking for info on the program currently showing, ie. teletext? But it cant find it. It doesn’t happen on all channels. I’ll dig into the freeview options later and see what is there?
5 July 2022 at 09:44 #35950andy_js
GOLD MemberB&O will probably need to do a software update to fix this – but they are pretty useless when it comes to updating the software of their products in general – and even worse for older products.
