Home › Forums › Product Discussion & Questions › BeoSound › Beovision Harmony display change
- This topic has 3 replies, 4 voices, and was last updated 3 years, 9 months ago by
Munir.
11 April 2022 at 08:19 #34067
Michael77
BRONZE MemberHello everyone,
I was thinking about a Harmony 77 and four Beolab 28s in my living room. I wanted to have a newer display, but B&O technical support told me that I cannot change the display.
Did B&O not promise that changes were possible? I would have liked a G1 or G2, but this seems to be impossible.
12 April 2022 at 02:24 #34068kawo
MemberI did change the display in the past (as I moved form a 65″ c9 to a 77″ CX). Challenge in the beginning was the software on the display which B&O had not adapted to the neweer WebOS. So that might be an issue on top that there might be new mounting plates.
but might only a question of time as B&O has to move on as supply of old generation display got out of stock.
27 April 2022 at 13:03 #34069Emilos88
BRONZE MemberIf you order a Harmony now, it should be with a LG G1,
The dealers order the display from LG, and LG do not have the old displays in stock.
This also means that B&O needs to adapt the spearker fronts to the new G2, as it is not as wide.
Lets see how fast this transistion is going.
24 June 2022 at 20:36 #34070Munir
BRONZE MemberI ordered a 77″ last week and it will be delivered with the G2 panel.
Favourite Product: Theatre
