Home Forums Product Discussion & Questions BeoVision BeoVision Eclipse Gen-1 Front Speaker Grommets
  • #124808
    Andrew McGee
    SILVER Member
    Hello, I have a 1st Gen Eclipse. The grommets that hold the front front speaker have decomposed and have become hard and brittle. Can you get any replacement parts?
    Thank you
    Andrew
    Favourite Product: Beolab 18
    #125003
    Andrew McGee
    SILVER Member
    This has been my temporary solution to the problem. I bought some grommets from Aliexpress:
    Black grommet with a 7.5 outer diam and a 5mm inner diam. You will 18 so buy a pack of 20.
    I bought 1.5mm thick plastic builders shims. Dimensions 14mmx12mm with an 8mm central hole. A few of them needed cutting down smaller to fit certain constrains. Use a heavy pair of scissors with a grated edge.
    This has held the speaker grill on. I am sure if I took the speaker grill of some of them will fall out. I have therefore left it in place with a view of not taking it off whilst I try and source some better fitting grommets.
    I have attached some pictures.
