Home › Forums › Product Discussion & Questions › BeoVision › BeoVision Eclipse Gen-1 Front Speaker Grommets
- This topic has 1 reply, 1 voice, and was last updated 2 months, 2 weeks ago by
Andrew McGee.
2 August 2026 at 12:30 #124808
Andrew McGee
SILVER MemberHello, I have a 1st Gen Eclipse. The grommets that hold the front front speaker have decomposed and have become hard and brittle. Can you get any replacement parts?
Thank you
Andrew
Favourite Product: Beolab 18
15 August 2026 at 23:10 #125003Andrew McGee
SILVER MemberThis has been my temporary solution to the problem. I bought some grommets from Aliexpress:
Black grommet with a 7.5 outer diam and a 5mm inner diam. You will 18 so buy a pack of 20.I bought 1.5mm thick plastic builders shims. Dimensions 14mmx12mm with an 8mm central hole. A few of them needed cutting down smaller to fit certain constrains. Use a heavy pair of scissors with a grated edge.This has held the speaker grill on. I am sure if I took the speaker grill of some of them will fall out. I have therefore left it in place with a view of not taking it off whilst I try and source some better fitting grommets.I have attached some pictures.Attachments:
You must be logged in to view attached files.Location: Australia
