Home › Forums › Product Discussion & Questions › BeoVision › Beovision AV9000 – no sound from speaker
- This topic has 7 replies, 2 voices, and was last updated 2 years, 1 month ago by
hector99.
6 February 2024 at 04:31 #52611
hector99
BRONZE MemberHi folks – thanks for having me :o) I think an AV9000 is classed as vintage now?
Just saved a Beovision AV9000 (TV, base, and remote) from landfill – should I just have let it go?..
It’s in good condition but has sat for 15 years. As with all AV things of this vintage – components will be on their way out.
Everything works fine apart form no audio from the speaker. There is audio via line out though so it’s not a total loss.
Does anyone know of any common faults with the amplifier board? Anyone fixing them or have spare parts? Or is it heading for it’s original destination?
Many thanks
9 February 2024 at 12:52 #52612hector99
BRONZE Membergoing, going…
10 February 2024 at 11:08 #52613 StoobieGOLD MemberTake a look here, you might not have the complete setup.
https://beoworld.org/prod_details.asp?pid=865
Stoobie
10 February 2024 at 11:32 #52614hector99
BRONZE MemberHi, Stoobie. I defininitely don’t have the complete setup – unfortunately. I would have thought setting the sound to – MONO – would have used only the integrated centre speaker though?
11 February 2024 at 20:25 #52615hector99
BRONZE Member2 fuses seem to be gone – F4 and F5 on the power supply in the ‘control centre’.
It’s a start I suppose…12 February 2024 at 18:28 #52616 StoobieGOLD MemberHi, Stoobie. I defininitely don’t have the complete setup – unfortunately. I would have thought setting the sound to – MONO – would have used only the integrated centre speaker though?
I’m sorry, I should have been clearer, I wondered if the sound controls are handled by the missing Master Control Panel AV9000.
However spec on Beoworld shows :-
Daily operation recommended: Beo4
Sound processing: Dolby Surround Sound, Pro-logic decoder Sound modes (sound 1-5) Mono (Centre speaker) It will auto-detect if speakers are added.So maybe Mono will work and there is another issue.
Stoobie
14 February 2024 at 19:07 #52617hector99
BRONZE MemberChanged the fuses but they immediately blew. Checking the bridge rectifiers – there’s a short between the AC terminals on one of them and not the other. They’re cheap so I’ll change them and see what happens. Super simple PSU so surely there’s not a lot to go wrong…
Feel free to chip anyone – I’ve not touched electronics for years and forgotten most of it!
Is this in the correct sub forum? Thought some electronic guru might have had something to say by now.
16 February 2024 at 20:59 #52618hector99
BRONZE MemberOh well – going by the dearth of replies I guess no one will be wanting any spare parts before it’s skipped…
