Home › Forums › Product Discussion & Questions › BeoVision › BEOVISION 7 NOT TURNING ON ?
- This topic has 11 replies, 5 voices, and was last updated 3 years, 5 months ago by
kwoffa.
29 October 2022 at 06:10 #40246
kwoffa
BRONZE MemberHi there ..just conected tv up and it will not turn on…I have the red standby light showing..but nothing else will happen..I have turned of and on again…there is no aditional things plugged into except the stand and lower speaker…please advise.Thank you.
29 October 2022 at 19:36 #40247 Guy
ModeratorFirstly are you sure that the remote is working? View the end with a mobile phone camera (iPhone selfie camera works) and see if you can see the IR transmitters glowing.
Otherwise, perhaps the TV is in V.OPT 0, where it does not respond to IR commands. To resolve this:
With the TV at standby/off.
On the Beo4, press the POWER (Red Dot) button and LIST together. Then press LIST until OPTION is shown, press GO (centre button), and then press LIST to show V.OPT. Then press 1. The power light on the TV should blink to show that it has been accepted.
Now try the remote and see if the TV will respond
29 October 2022 at 20:26 #40248kwoffa
BRONZE MemberHi Guy…Firstly thanks for replying ! I cannot see anything glowing on the end of the remote…so i think i will go to the B+O shop and get it checked out first….then check your other ideas…I really apreciate your help and will be in touch regarding the outcome..Thanks.
29 October 2022 at 20:33 #40249kwoffa
BRONZE MemberGuy…Whoops yes can see the remote working..
29 October 2022 at 20:39 #40250kwoffa
BRONZE MemberJust tried your idea and no joy..no flashing red light.and remote goes to radio.
30 October 2022 at 08:07 #40251carlos99
BRONZE MemberSounds like it may be a defective power board, had there been any issues prior to the failure, such as screen flicker or stand control problems?
30 October 2022 at 08:29 #40252kwoffa
BRONZE MemberMorning…No problems at all TV has been great..Just wont turn on now.
30 October 2022 at 16:34 #40253carlos99
BRONZE MemberAre you able to move the stand using the remote control when the set fails to switch on?
31 October 2022 at 17:11 #40254kwoffa
BRONZE MemberThanks very much for all the interest and solutions…..I called a B+O Engineer in…and all is sorted now…Thanks again.
31 October 2022 at 18:14 #40255 MillemisBRONZE MemberCongrats on that.
I guess not just I would want to hear what was wrong and how it was sorted!
1 November 2022 at 00:29 #40256 9_LEEBRONZE MemberAs above – what MM said. Always helps to know what the solution was in order to help future members with the same issue.
1 November 2022 at 09:33 #40257kwoffa
BRONZE MemberI get this….and i think it was a simple thing inas much as …I think it was a simple case of a wrong wiring up..which caused the TV to fail.
