Home › Forums › Product Discussion & Questions › BeoVision › Beovision 7 floor stand – quick question
- This topic has 2 replies, 2 voices, and was last updated 1 year, 8 months ago by
CharlieWednesday.
15 July 2024 at 19:32 #57430
CharlieWednesdayGOLD MemberI have not been able to figure this out so in case anyone knows – would the motorised floor stand item 1404111 for a BV7-40 also work with a BV7-32? Is the bracket the same size?
15 July 2024 at 19:53 #57431 GuyModeratorNo. The 7-40 bracket (the bit that actually supports the TV) is much wider – you can see that it has levers going into each of the two support poles.
The BV6-26 brackets will support the BV7-32 (but won’t necessarily have the bracket mount below the TV for a Beolab).
16 July 2024 at 14:26 #57437 CharlieWednesdayGOLD MemberYes I did think that when I looked at the photograph, but wanted to be sure. Thanks for confirming.
