Home › Forums › Product Discussion & Questions › BeoVision › Beovision 7 55 – Airport Express
- This topic has 4 replies, 3 voices, and was last updated 3 years, 11 months ago by
kirangohel.
3 May 2022 at 08:05 #34506
first4580
BRONZE MemberHi, I have a BV 7 55 MK2 with BL7-6, Bl 8000 & BL 6000 & Besound 4
I wonder if I can listen my musics thru airplay without turning on the TV.
Before buying the TV and audio, I used to connect my airport express directly to my BLs’ line in socket, so I didn’t have to turn on any devices beside using my iPhone.
As turning on TV is quite bothering, I hope there is a solution..
At least, I hope that I can turn the screen off (usually I listen to music when I’m in bed..)
If I have to, I’m willing to buy extra devices
Thank you for your advices guys!
3 May 2022 at 09:07 #34507 GuyModeratorHave a look at this: https://shop.oneremote.dk/shop/69116-powerlink-aux-adaptor/4154-powerlink-aux-expander/
Although I have no experience of this device, it seems to do exactly what you require. I have used other OneRemote products in the past and have been very impressed.
4 May 2022 at 05:14 #34508first4580
BRONZE MemberThx a lot! I’ve ordered it
4 May 2022 at 10:09 #34509 GuyModeratorThx a lot! I’ve ordered it
Great. When it arrives come back to the Forum and let us know your thoughts ?
4 May 2022 at 21:16 #34510kirangohel
GOLD MemberWould a BeoSound Core work in this mix?
I’m trying to do the same – BeoVision Avant Powerlink to BeoAmp 2 ceiling speakers. I will add a BeoSound Core in this mix for Airplay and other music sources.
When I press Airplay to the Core, where would the sound come from?
