Home Forums Product Discussion & Questions BeoVision Beovision 7-40 MkII Masterpin / Pincode entry problem
Viewing 8 posts - 1 through 8 (of 8 total)
  • #43994
    Rotti
    According to the hint of a fellow member, I give it a try in english to enlarge my range, as I have a weird problem:
    Got a BV 7-40 a couple of days ago in Denmark. The TV asked for a 4 digit PINcode on the first switching it on.
    (No chance of getting the originally applied code, no documents available, as it came from a “kirkens korshaer”)
    So I used my Beo4 (old model, not joystick) to enter some random combination  tries like 1111, oooo, 1234 and 9999 in the beginning.
    No surprise, the TV locked itself, as they were all wrong. 3 hours later, input was possible again, but -thanks to the internet- I found out, that it makes no sense without a mastercode.
    Next day I contacted the nearby B&O dealer and got amazingly fast help, they sent me a Master Pin code. So far, so good.
    BUT
    The MPC is 5 digits, the regular pin is 4 digits.
    Operation manual says “press and hold << when asked for pincode, and the set will switch over to 5 -digit MPC input”.
    However, this won´t happen.
    It reacts on pressing the <<(backward) button by switching into regular 4 digit entry. (“Next”). No master PIN menu, neither by tapping, nor by holding <<. It even switches off after around 30 seconds of pressing <<.
    Regardless of that, it reacts on the <<command, when I´m in the input procedure, I can choose the 4 digits fore- and backwards, which tells me, that the remote control is
    -working
    and
    -the TV “understands” what I´d call the “syntax”.
    Anyway, there must be a mistake, or a trick to it.
    I can´t tell, if there were changes aplied to my Beo4, as it came along with an overture system some day. Neither concerning the TV
    Did anybody of you ever face the same problem?
    Is there a chance to lock it by coincidence when entering random false PIN codes? Maybe making unwanted changes to a hidden menu?
    I found out, that there must be some kind of 4-digit code that makes the set work for about half an hour, regardless of any pin entries, just for test issues, but I didn´t find that one either. Unfortunately, I hsave no access to any kind of service manuals or so.
    Thanks in advance!
    #43995
    Guy
    According to the service manual, when 5 pin code attempts are made the TV locks for 3 hours, and cannot receive any commands. The three hours must be spent with the TV in stand-by for the timer to run (with the TV connected to mains power – red light on). After 3 hours, the pin code counter is reset.
    Yes there is a ‘service code’ of 1 1 1 1 1, but you need to be in the Master code menu to enter it! If it worked it would give you 12 hours of service time.
    EDIT: If you join the Forum as a SILVER or GOLD member you will be able to download the full service manual. ?
    My B&O Icons: No description available No description available No description availableNo description availableNo description availableNo description available No description available No description availableNo description availableNo description availableNo description availableNo description availableNo description availableNo description available
    #43996
    Rotti
    Hello Guy and thanks for the quick response.
    I already faced the “downtime” of 3 hours twice  and the set came back to life after this regularly.
    No matter what I do, I don´t get access to the master code menu. That seems to be the root of all evil.
    I´m not really sure, if it´s the fault of the remote control, as all buttons are working and are recognized by the TV somehow. Still have another Beo4 here, but it doesn´t work right now. ( Display vanishes as soon as a button is pressed and reappears after letting it go, but that´s another topic. Mentioned it only to point out, that there is no choice to try anoter RC at the moment).
    Service manual sounds good, as the set seems to have starting issues from time to time, maybe as a result of a faulty power supply (capacitors or stuff?) , but that´s a thing, I will have to take care of another day.
    I´m not really sure, if there is something special , that I didn´t realize or that I was probably doing wrong, but the longer I think it over, it seems that the menu is kinda blocked or the remote doesn´t exactly fit(??). Usually, the designers will prevent end users from doing inappropriate entries by coincidence, but who knows??? Maybe there´s a second stage of entry options or stuff? User´s man doesn´t relate to that, no warnings.
    #43997
    Guy
    View the end of the remote with an iPhone’s selfie camera (or similar) and you should be able to see the two IR emitters flashing faintly. When you press and hold the << button do they keep pulsing, or only flash once?
    #43998
    Rotti
    they flash/work permanently, if I press and hold the button. The TV notices that, too. It just does´t react in the desired manner. If the set is in “code entry mode”, I can shift the cursor left and right with << and >>. But it will not get into mastercode entry mode. No matter, what I do. Also doesn´t jump with other keys
    #43999
    Rotti
    Ok, there is nothing worse than a thread asking for help and not posting the outcome in the end.
    I finally found the solution to this problem:
    Just use a Beo4 – “joystick model”
    That´s all.
    Rest works as described.
    I have no idea, why it wouldn´t work out with a standard Beo4, but it´s a solved problem now.
    Just posting, in case someone faces the same problems.
    #44000
    Guy
    Great news indeed – many thanks for coming back and letting us know the solution!
    #70651
    Alexander Luft
    GOLD Member
    Similar problem.
    solved by using a different beo4
    There are different versions of the beo4 remote.
    be sure yours has a DVD button on row two from the top.
    Signature: Vintage B&O audio. Bs 9000 bl 8000 Beovision 7
    My B&O Icons: No description available No description availableNo description availableNo description availableNo description availableNo description available No description available
