Home › Forums › Product Discussion & Questions › BeoVision › Beovision 7-32 HD connections
- This topic has 2 replies, 3 voices, and was last updated 1 year, 3 months ago by
Guy.
29 October 2024 at 09:05 #60550
Roger Wilson
BRONZE MemberMessage
I have a 2007 Beovision 7-32 HD with Scart sockets leading to a dish based Humax 500 Mb recorder box. This box is failing but replacing with a new Freesat HDMI recorder is causing problems because there is no HDMI socket on the B&O and an HDMI converter to Scart doesn’t work – I’ve already tried it.
I’m told that it’s possible to use the DVI socket via a HDMI-DVI cable but with phono-stereo jacks too, presumably for sound? Would the phonos connect to the sound stereo jack or Optical socket on the Freesat box?Attachments:
You must be logged in to view attached files.27 November 2024 at 21:14 #61193ethuijs
BRONZE MemberI have connected the audio to the chinch connections at the top right.
27 November 2024 at 21:42 #61196 GuyModeratorMessage I have a 2007 Beovision 7-32 HD with Scart sockets leading to a dish based Humax 500 Mb recorder box. This box is failing but replacing with a new Freesat HDMI recorder is causing problems because there is no HDMI socket on the B&O and an HDMI converter to Scart doesn’t work – I’ve already tried it. I’m told that it’s possible to use the DVI socket via a HDMI-DVI cable but with phono-stereo jacks too, presumably for sound? Would the phonos connect to the sound stereo jack or Optical socket on the Freesat box?
Sorry but I didn’t see this when originally posted!
Welcome to Beoworld, and perhaps you’ll find that my post in this thread helps explain how to use an hdmi audio extractor to solve the problem: https://forum.beoworld.org/forums/topic/hdmi-connection-for-beovision-7-mk1/#post-1606
