Home › Forums › Product Discussion & Questions › BeoVision › Beovision 14 android issue
- This topic has 6 replies, 3 voices, and was last updated 3 years, 5 months ago by
kuyttendaele.
10 August 2022 at 04:37 #36924
cprelise
BRONZE MemberBeovision 14 android issue
I read about there was a lot of software/android issue with Beovision 14 other android version tv. Was the issue ever fixed before B&O abandoned the TV I tried back in time BeoSound Moment and experinced that B&O just was running away from the problems and shutdown the production of the product so wonder if this is the same story with the TV
16 August 2022 at 14:21 #36925 kuyttendaeleMemberBV14 user here… When the BV14 was released in 2016 is was a software disaster. But after a number of software updates mine has been working perfectly fro the last couple of years. From memory I think that the last software update was released end 2019.
16 August 2022 at 14:35 #36926cprelise
BRONZE MemberThanks Kuyttendaele 🙂
Do you know if the included all HBOmax, Netflix & AmazonPrime in there app list ?
17 August 2022 at 16:28 #36927 kuyttendaeleMemberI don’t use the built in apps… I use an Apple TV. (which you can perfectly controle with the BeoRemoteOne BT)
Karel.
17 August 2022 at 17:40 #36928cprelise
BRONZE MemberThanks Karel
You are very helpful 🙂
Any change you know if the Arris BCX525e set-top box is in the the PUC list ?
B&O is holding their card very close to the body :-/
17 October 2022 at 15:43 #36929Mickey
BRONZE MemberHello,
I’m considering buying a BV14 from an old lady that went to retiring home, 2nd hand. She bought it in december 2018. What android version should this have? I think she never updated it so…
I’d like to propose the seller (her son) that I spend some time testing the android …
- log in google
- Spotify works?
- browser works?
- youtube?
- Check the software version.
- built-in Chromecast working?
Any other things I should check ? Should I bring the latest lollypop on a USB drive?
Thanks for your help!
18 October 2022 at 09:24 #36930 kuyttendaeleMemberLast update was Sept ’19, version QM153E.0.8.2.015
Spotify & Youtube work. Netflix doesn’t; don’t know about the rest.
However… Attach an AppleTV 4K. Much easier, fully integrates with PUC and future proof.Karel.
