Home Forums Product Discussion & Questions BeoVision Beovision 11 radio channels (via DTV)?
  • #123736
    CharlieWednesday
    GOLD Member
    My Beovision 11-46 has only been used for watching external sources before now, but I decided to connect an aerial to it and tune in the DTV channels, because I realised that the DTV service would also give me BBC Radio stations.  I can get BBC radio stations on my Beosound 9000, but not all of them – Radion 6 for example is not broadcast on FM, only on DAB.
    I tuned the TV and saw both TV and Radio stations appearing as they were found, then I stored the tuning, but once I go to the guide, I can only find TV channels?  The BBC radio stations should be channel number 700 onward, but those channels don’t show in the guide – it stops at 699 (an adult TV station!).  So, only TV channels are showing in the guide, no radio stations at all.
    I’ve tried looking through the settings for favourites, groups, channel lists and so on, but I can’t seem to find a way to access the radio stations.  In the user guide it says that you can add a radio station to a group but you have to select the radio station first in order to get that menu option – as I can’t tune in to any DVT radio stations, that’s not possible.
    My other (Sony) TV shows radio station up in the high channel numbers (700 and above), but they are missing on my Beovision 11-46, even though I could see they were found during the tuning process.  Any ideas?
    Guy
    On my BV10 with Freeview tuner, I have to press MENU then RED to switch from TV to RADIO (straight to channel 700), and the same key presses to get back to TV.  Is it similar on BV11?
    EDIT:  Mine would appear to behave as shown on page 6 the DVB-HD User Guide here:  https://bangolufsenassistentgohe.blob.core.windows.net/manuals/APPS_AND_ACCESSORIES/DVB_HD/dvb-hd_userguide_english.pdf
    • This reply was modified 20 minutes ago by Guy.
