Home Forums Product Discussion & Questions BeoVision Beovision 11, No Picture
  • #76214
    sandor.szucs
    SILVER Member
    My Beovision switches on and there is sound but no display. As soon as I opened the back it became evident that the 2 safety capacitors have been burned out on PCB04(power supply BCB).
    Surprisingly they are RIFA capacitors notoriously known for their failures. I would like to replace them with a more reliable brand.
    Would anybody know the specification for these capacitors?
    #76229
    Madskp
    GOLD Member
    <hr />
    Take a look at this thread where the Rifa capacitors was blown in a Beoplay V1.
    https://forum.beoworld.org/forums/topic/beoplay-v1-40-smoked-power-supply/
    The bBV11 and the V1 is built on the same platform, so there is a good chance the capacitors are the same.
    #76348
    sandor.szucs
    SILVER Member
    Hi, Madskp,
    Thanks very much for your help.
    #76390
    sandor.szucs
    SILVER Member
    Anybody who is looking for the same capacitors will find them at the web address bellow:
    https://www.aliexpress.com/item/1005010544497927.html?spm=a2g0o.order_list.order_list_main.9.7eeb1802PGeDSR
    #99543
    sandor.szucs
    SILVER Member
    So, I got and installed the new capacitors but it made no difference – there still is no display (picture).
    Is there a way I could test power supply PCB 04 while it is out of the TV on its own ?
    After I replaced the capacitors, I had PCB 04 assembled to the TV and using the service manual diagnostic flow chart (for symptom: No Picture) I did the checks and ended up with the conclusion that PCB 01 should be replaced. However, I am still not sure after those checks if PCB 04 is in fact OK or NOT OK. The service manual does not offer any test methods to determine if a particular PCB circuit functions OK or NOT OK.
    Could someone help me with this please?
