Home › Forums › Product Discussion & Questions › BeoVision › Beovision 11 55
- This topic has 7 replies, 5 voices, and was last updated 2 days, 15 hours ago by
B Schukkink.
24 April 2023 at 02:57 #46017
Ckbrookes
BRONZE MemberHi All
has anyone attempted to replace the led panel on a Beovision 11 55
col
24 April 2023 at 15:21 #46018jvezina
GOLD MemberThere is a service manual for the Beovision 11-55 in the technical section of Beoworld that explains how to disassemble the set. The B&O service procedure is to replace the entire LCD panel if the LED strips are defective.
Good luck,
Jean
My B&O Icons:25 April 2023 at 10:49 #46019Ckbrookes
BRONZE MemberHi Jean
yeah I have a few vertical lines, I have looked at the service manual it looks doable, but do we know make and model of the panel?
kind regards
col
25 April 2023 at 14:32 #46020jvezina
GOLD MemberVertical lines ? Then it is not the backlight system . It may be the video engine or the T-Con board. The service manual has fault finding flowcharts.
But, can B&O service the set ? If spare parts are still available, then it is the solution, although possibly expensive.
Good luck,
Jean
My B&O Icons:25 April 2023 at 16:05 #46021BRONZE MemberIts a Samsung panel and as far as I have heard there is no panels available as spares.
I guess these panels where bespoke when it comes to the fittings and built on spec by B&O.
Removing the panel is not that complicated though…
19 December 2023 at 07:25 #46022ahendra
BRONZE MemberHi All,
I am trying to replace the black bezel with a Chrome variant that comes from a broken panel. Possible? I understand a new panel comes with bezel. Would anyone care to share the service manual. Thanks All in advance.
Angus
20 December 2023 at 14:58 #46023BRONZE MemberYou can access service manual if you become paying member on this site.
The bezel is fixed to the glass, if that is what you mean, so you swap the whole thing if you want another bezel.
28 May 2025 at 09:51 #65858B Schukkink
SILVER MemberHello,
Can somebody tell me were to find the manuel for replacing the lcd panel on my beovision 11-55?
can’t find it on the site!
i am a silver member, so hopefully somebody can help me out!thanks
Bart
