Home › Forums › General Discussion & Questions › BeoWorld Feature / Problem › Beovision 11/46, motorized wall bracket
- This topic has 1 reply, 2 voices, and was last updated 1 hour, 39 minutes ago by
vikinguk.
6 May 2026 at 06:09 #123490
Herbert Brantl
BRONZE MemberGood morning,
I recently acquired a Bang & Olufsen BeoVision 11-46 with a motorized wall bracket. The television works perfectly; however, there is an issue with the wall mount. The motor appears to have moved to its end position and can no longer be controlled using the remote.
I have tried to resolve the issue through the settings, but without success. I receive a message prompting me to set the end positions (maximum angle and parallel to the wall), which I enter and which the television confirms. After that, nothing happens—there is no prompt or response to control the motor.
As I am new to Bang & Olufsen, I was wondering if there might be something simple I have overlooked or a trick to reactivate the motor.
I would appreciate any help.
Best regards,
Herbert Brantl-
This topic was modified 6 days, 18 hours ago by
Herbert Brantl.
12 May 2026 at 23:20 #123543 vikinguk
BRONZE MemberDid you fold the TV manually back to its parallel wall position? (The motor makes a ratcheting noise when you do this).
Graham
