Home › Forums › Product Discussion & Questions › BeoVision › Beovision 11-46
- This topic has 5 replies, 4 voices, and was last updated 2 years, 8 months ago by
trackbeo.
28 July 2023 at 01:09 #47938
jocar57
BRONZE MemberHello, First time posting on this forum.
I am trying to find out how to get into the service menu on a Beovision 11-46 to view the usage hours.
The reason for asking is I have come across this Tv for sale and it is in very good condition and thinking of buying it.
Many thanks
28 July 2023 at 15:39 #47939 GuyModeratorAccording to the Service Manual, there’s a ‘Customer Service Menu’ but I don’t think it shows the ‘counters’. To access:
Press the MENU button on the remote control, choose ‘Setup’, and press the
Centre button. Press RED button and within 3 seconds press the Centre button.However, to get to the ‘counters’ (usage hours), I think that you have to connect a Service Tool.
And welcome to the Forum!
EDIT: On the older BV10 you got to the Service Mode by pressing MENU then 0 0 GO within 3 seconds, so you could give that a try!
29 July 2023 at 06:15 #47940Madskp
GOLD MemberAccording to the Service Manual, there’s a ‘Customer Service Menu’ but I don’t think it shows the ‘counters’. To access: Press the MENU button on the remote control, choose ‘Setup’, and press the Centre button. Press RED button and within 3 seconds press the Centre button.
I can confirm this is how the customer service menu is accesed on a Beoplay V1 ( same platform). But I dont see counters anywhere, so it might only be via the servicetool as Guy mention.
29 July 2023 at 09:46 #47941Madskp
GOLD MemberOn the older BV10 you got to the Service Mode by pressing MENU then 0 0 GO within 3 seconds, so you could give that a try!
I tried this on my Beoplay V1, but I can’t get that combination to work. It will just acces the menu, ignore the 0’s, and select the first menu item
29 July 2023 at 10:52 #47942jocar57
BRONZE MemberMany thanks Guy and Madskp .
I’ve tried the BV10 method before posting and can confirm that does not work.
I’ll try the Beoplay V1 method and report back.
29 July 2023 at 16:20 #47943 trackbeoBRONZE Member[deleted]
