Home › Forums › Product Discussion & Questions › BeoVision › Beovision 10-46
  • #33224
    Anonymous
    Inactive
    I am pretty sure that in “old” forum there was manual of how to “dismantle” the back of a BV-10 46 to have a look inside the trunk of the TV. Need to have a look at the cables, t con etc.
    Anyone who can help me?
    #33225
    Beoaddict
    I was also pretty sure there were service manuals for the (then) new BV10s back in 2011/12, but it seems to be impossible to find them here or elsewhere.
    I have also failed to open the back cover and just asked the same question here.
    Have you succeeded to open the damn thing up in the meantime since march?
    I am quite desperate, as this giant lump of a TV has to go if it is beyond repair.
    Kind regards, Phil
    #33226
    Beoaddict
    Problem solved – an old man living in a cave full of ancient technology hidden away from the world occasionaly shares his wisdom in all things B&O with us mere mortals before he vanishes again for decades, and I was at the right place at the right time.
    So here we go: The internals are accessed via the front of the TV – at least in the case of a 10-46, in order to gain access, remove the screws at the bottom, then flip over and gently slide off aluminium frame and glass, and you’re in. Have fun.
    #33227
    trackbeo
    For dullards like me to whom this is not obvious, by “screws at the bottom” @Beoaddict means “at the bottom edge of the rear panel,”  and “flip over” means “…so it is resting on its rear panel on your floor/bed/…”  The service manual instead assumes you have a service stand holding the TV upright, so you would be sliding the front glass/frame assembly up vertically.  (I’m pretty sure it was available here, to gold members?  Anyway, it’s board-level service only.)  Here are the screw locations.
    BV10_service_p46
