Home › Forums › Product Discussion & Questions › BeoVision › Beovision 10-32 Stuck on Setup
- This topic has 2 replies, 3 voices, and was last updated 3 weeks ago by
Peter Rutt.
14 January 2026 at 22:59 #72556
B&O Orlando
BRONZE MemberHi all,
I have a Beovision 10-32 from Denmark that I am using in USA. When going through first time setup, I cannot pass the section where you setup and search for TV stations. If I select none of the options, I cannot continue, and if I select any of the options it searches for channels, finds none, and then I still cannot continue. I find it hard to believe that I MUST tune TV stations to finish the setup. I can still use the TV as I can switch to an HDMI input, but whenever I turn it on it initially wants me to go through the setup.
Any ideas?
15 January 2026 at 12:40 #72560 GuyModeratorCan you get into the ‘Options’ menu and turn off the Tuners? Both analogue and DVB-HD if there.
Alternatively, try going to the Service menu* and find the option ‘RESET TO FACTORY SETTINGS’. Then try setup again.
* The Service Menu must be activated while the TV SETUP menu is displayed. From
this initial state, the Service Menu is activated in the following way: Beo4: the Service Menu is activated by pressing 0 0 GO within 3 s.Location: Warwickshire, UK
13 February 2026 at 16:28 #73687Peter Rutt
BRONZE MemberI’ve just inherited a Beovision 10-32 from an old friend… but no remote, so I can’t even tell if it’s working! Red light comes on when powered on: I have a ‘universal’ remote which lists a setting for B&O tv’s (it says use code 014) but the 10-32 just sits & sulks. Does anyone know a low- cost alternative to buying a Beo4 from eBay? I want to find out if the 10-32 works before spending £70 or more on the real thing!
