Home Forums Product Discussion & Questions BeoVision Beovision 10-32 cannot find HDMI signal
Viewing 11 posts - 1 through 11 (of 11 total)
  • #71259
    Gab Kan
    I just bought a BV 10-32 (Type 9541) in an auction and to my disappointment I cannot manage to get image feed from the HDMI connections.
    I have never had a BV before so I am new to the setup. But I have read up as much as possible without success.
    Please help if you have experience or a clue of how to resolve this issue.
    The screen seems to work, I can see the back light turning on and the B&O greeting when turning on the tv, the menu is visible and so are the names of the sources when changing source.
    This far I have tried all 3 HDMI connections, with both my Tele2 dongle, a chrome cast unit from a Swedish television provider and my computer (Mac).
    I tried setting both the computer and the dongle up as PC. I tried various other sources (dvd, v.mem, dtv) for both of them. The only difference I noticed was that I didn’t get “static” from TV-source, when the dongle was plugged in.
    The Mac does not detect the TV being connected as speaker or screen when connected though a HDMI cable.
    My family is really happy with the beautiful TV and we would be grateful if we could keep it :•)
    Any suggestions?
    • This topic was modified 3 months ago by Gab Kan.
    #71262
    CharlieWednesday
    GOLD Member
    I’ve never owned a BV10 but on the BV7 and BV8 (which I have owned), you need to tell the TV which HDMI socket is used for each input.
    In the BV7 or BV8 you would go to Menu, then Connections, then select one of the available AVs from the list.  Once selected, you would choose which source that connection would respond to (V.Mem, PC, DVD and so on), and which HDMI socket it would use.  Press OK/Play to save it, and it should work.
    Ravsted
    This is how the menu is on my 10-40.
    Turn on TV: Beo4 TV
    Beo4: MENU
    Beo4: MENU (press again within few seconds)
    This gives a menu with 4 options.
    Choose ‘øvrige muligheder’ (other options)
    Choose ’tilslutning’ (connections)
    This is where you ‘map’ a AV socket (e.g. a HDMI input) to a source button on the Beo4.
    I have AV1 mapped to DTV
    AV2 mapped to V.MEM
    AV3 to DVD
    So… Those 3 buttons on the Beo4 now select either of the 3 HDMI inputs.
    Hope it helps.
    #71295
    Guy
    All the relevant BV10 documentation is available from B&O in various languages here:  https://support.bang-olufsen.com/hc/en-us/articles/360041518732-Beovision-10
    Make sure you follow the instructions in the ‘Connections’ sections, and hopefully all will become clear!
    Gab Kan
    Turn on TV: Beo4 TV
    Beo4: MENU
    AV2 mapped to V.MEM
    AV3 to DVD
    Hope it helps.
    Thank you for your reply and thorough instructions. What you describe is exactly what I have done. I tried different source buttons/list items and no luck 🙁
    #71298
    Gab Kan
    Thanks for sharing, Guy. I’ve followed the instructions found in the manual. But no luck unfortunately…
    #71299
    Gab Kan
    I just wanted to add that I tried the HDMI cable with another device and it is working fine.
    #71300
    Ravsted
    Strange.
    I don’t know if this can help somehow. I assume these are the correct ‘terms’ in English. My GUI is DK.
    Under
    Menu, menu, other options, connections, AV1 …. I got:
    Source: DTV
    IR: None
    HDMI: A
    S/P-DIF: None
    One more thing… Long shot.
    Under
    Menu, setup (4), other options, HDMI
    HDCP: On
    Pressing DTV changes to HDMI socket ‘A’ where I got a gen 2 Chromecast connected.
    Try power cycle the TV. Remove from mains in 10 mins.
    #71301
    Ravsted
    And another option… Try at own risk. Personally I never did such a reset. Others might know if this is a good idea.
    Press:
    TV
    Menu, menu
    You now got the menu with 4 options.
    Press
    Menu, 0, 0, GO (you need to be pretty quick)
    This will take you to the ‘hidden’ service menu.
    You can enter a menu item with ‘GO’ and leave with ‘STOP’ (on my non-joystick Beo4).
    Under ‘settings’ there is the option to ‘reset all features’. Other who have tried can explain the consequences. I assume this will reset to factory settings.
    #72522
    Gab Kan
    I left the TV with a local BO repair man. Who diagnosed a faulty main board. I haven’t spoken to him about the details yet but I guess it doesn’t come as a big surprise as the HDMI connections are on the main board.
    Would you consider it worth looking for a functioning second hand pcb-14? Are they model specific?
    Best regards.
    Gab
    #74095
    Peter Rutt
    Nice 0ne Ravsted… I’ve just powered up my 10-32 and linked a fairly new DVD player (with built-in Smart TV options incl. Netflix etc) via the HDMI ports, using the info in your first post above:- worked 1st-time.  Thanks!
    PS where can I buy the Powerlink plugs so I can solder up a cable from the Beovision to my Beolab 7.1?  I need to make a longer one than the old one I have…..
    All best, & thanks!
