Home › Forums › General Discussion & Questions › General Discussion & Questions › BEOTOOTH 5500 : A Datalink Bluetooth Receiver
- This topic has 62 replies, 17 voices, and was last updated 2 months, 2 weeks ago by
pilatomic.
4 December 2023 at 15:18 #50238
pilatomic
MemberYou could evaluate lowering the series resistance of the RC filter on the PCM5102 output a little. Otherwise you won’t be able to hit the THD+N value they are mentioning in the datasheet. Some TI reference designs are….
That’s interesting ! Any insight on the mechanism that lowers the THD here ? Too much drop through the resistors ?
Someone in love with tantalum caps? ? .
Oh yeah, I really like their yellow color ! Joke aside, I’m using the venerable LM1117 LDO to provide +3.3V rails, and the recommended output cap is a 10µF tantalum (that’s also a TI design), so ceramics probably lack enough ESR to reach stability here. Used here as regulator outputs caps, the dV/dT is no issue, 16V caps on 3.3V rail, and with low current (0.35A) polyswitch on the supply (and a 6V TVS), I’d say we’re in a correct configuration for tantalums caps, don’t you think ? 🙂
Bonus point is virtually no aging, and no microphonic effect (but that’s a bit of a moot point when used as decoupling caps).Location: France
4 December 2023 at 16:51 #50239B3OHACK3R
BRONZE MemberThat’s interesting ! Any insight on the mechanism that lowers the THD here ? Too much drop through the resistors ?
Only noticed when measuring a PCM5122 on the audio analyzer (pretty much the same chip on the analog output). Never made much assumptions why this is actually the case. In-field you will either see the 470R from the datasheet / EVK being used or a value around 100 … 75R. The ones with a lower value were likely be tuned with a proper analyzer, the others are probably just copy-paste. Just make sure you have proper ESD protection. Also sometimes they don’t like a ferrite bead (FB3?) in front of the analog power input. Better to have the whole system powered by a buck converter and only have a small LDO for the analog part of the DAC.
With exception of the PCM5242 (convenient if you need symmetrical output) I stopped using those TI DACs a while ago because they also seem to have a higher variability in quality than usual. E.g. ESS has a part that is pretty similar to the PCM5102 and has no such issues.
Not that all that would make any difference when connected to vintage Beo gear… 😉and the recommended output cap is a 10µF tantalum
You mean 100 uF, right? Which is likely also the reason why they are recommending tantalum caps. Ceramics in that range are quite a bit more expensive (and probably weren’t even available back when that LDO was designed – same goes for low-ESR electrolytics).
Personally I don’t like tantalum much. Only use it if there is no way around. Although they still have the highest density with lowest ESR they also really dislike repetitive and excessive in-rush current. They tend to go up in flames if they are unhappy with their environment. Then there is also the fact that it’s a conflict resource…
Alu-Poly is a great alternative if normal electrolytics or ceramics won’t cut it.4 December 2023 at 20:29 #50240 pilatomic
MemberOnly noticed when measuring a PCM5122 on the audio analyzer (pretty much the same chip on the analog output).
Would you happen to recall the output load characteristic during that test ? Having a relatively low (~1k) load impedance could definitely degrade that THD.
No, really 10µF. That’s what the LM1117 is characterized with (the 3.3V fixed version, not the ADJ one). It requires the output cap ESR to be > 0.3R, which already excludes ceramic caps.
4 December 2023 at 21:37 #50241B3OHACK3R
BRONZE MemberWould you happen to recall the output load characteristic during that test ? Having a relatively low (~1k) load impedance could definitely degrade that THD.
I’m usually measuring at 10k. It is a known “problem” with those DACs. Same goes for the output volume. It only shows optimal THD+N at around -1.5 dB. Any higher and it will degenerate (saturate the output stage?).
Ah, I see. Was only quickly looking at the reference schematic where 100 uF is used. Been quite a while since I was using such higher power LDO. Mostly switching buck converters nowadays and only small / modern LDOs with high PSRR for noise optimised low-power stuff.
18 December 2023 at 22:25 #50242 pilatomic
MemberGood evening,
Sorry for letting that many days go by without updates, I originally planned to write last week about my avancement,
but I caught the covid in the meantime, and while the novelty factor has dry out, the fever is still quite effective.Anyway, I’m now back on my feet (mostly), so here are the news :
Following B3OHACK3R’s concerns about the usage of tantalum caps, I went looking for other regulators that would be stable with ceramic caps.
I found a new Texas Instrument part, the TLV761 : it is stable with output ceramic caps, has a lower Vdrop and a better PSRR than the LM1117 I originally selected,
which both means less noise when used on a noisy USB-C supply. Bonus points, it is pin compatible with the LM1117, and comes with a soft start function ! Perfect !
I’ll be using those with cermic caps from now on.I did make some (rough) measurement of the PCM5102 DAC using my PC soundcard input to investigate the impact of changing the value of the output filter resistor.
Going from 470R to 100R produces a small (around -6dB) improvement of a bit of 50Hz present in the output. But that noise was already at a ridiculously low level (-90dB).
I reckon it lowers the output impedance of the system, making it a tiny bit better at ignoring the 50Hz ambiant noise ?
The improvement seems ever so small in my case, I don’t think I’ll implement it.I also spent a bit of time working on the firmware. I does now identify itself as a USB CDC device when plugged to a computer,
which means you can connect to it with a terminal emulator (such a Putty), and get a command prompt.
Only 3 commands are supported now : querrying the firmware version, querrying the device bluetooth name, and setting the bluetooth name.
That means if you have multiple Beotooth, each one can be named to reflect the system it connects to.
More commands might be implemented in future firmware versions.I did mill about a dozen enclosure, and the result is even better than the first I did, so now I have everything required to build the first few Beotooth.
I’ll be writing to those who sent me messages as soon as I am ready to ship theirs.Wishing you all healthy holidays !
18 December 2023 at 23:22 #50243 Rolf2GOLD MemberHi Pilatomic,
good news, really looking forward to it! Healthy holidays to you from now on.
Kind regards,
Rolf
Favourite Product: BeoSystem 4500
23 December 2023 at 08:24 #50246 MillemisBRONZE MemberAmazing!
23 December 2023 at 19:01 #50244 pilatomic
MemberHello,
Right before the Christmas celebrations, as I have started shipping some Beotooth 5500, I have just put together an assembly / usage manual. You can find it there :
https://pila.fr/wordpress/wp-content/uploads/2023/12/Beotooth_Manual_V1.0.pdf
Wishing you all a merry Christmas from France !
23 December 2023 at 20:12 #50245Madskp
GOLD MemberLooks very promising ? Great job and merry christmas to you
6 January 2024 at 18:28 #50247Gspaltenhorn
BRONZE MemberHey Pila, really nice project you put together here!
I´m currently looking into creating something less sophisticated for my personal use. The idea is to control a Beomaster 6500 by transmitting Datalink commands. I´m using an off-the-shelf Arduino Uno R4 WiFi and as a code basis I used this GitHub Project.
Currently I can send and receive Datalink commands on the TV/AUX Port of the BM and I was able to retrieve commands from a MCL Sensor I bought for this Project. But unfortunately the commands only startup the BM in muted state and I can´t get it to unmute (See my post here).
I think I´m lacking a deeper understanding of the actual structure/content of the Datalink protocol beyond the published Datalink’86 spec-sheet.
As it seems you succeeded in solving these difficulties, do you have some tips and tricks or a documentation about Datalink you are willing share?Any advice is welcome!
6 January 2024 at 20:51 #50248B3OHACK3R
BRONZE MemberBut unfortunately the commands only startup the BM in muted state and I can´t get it to unmute
Hi!
Maybe I can jump in here. Was busy with ML lately and haven’t had a deep dive in the DL’86 protocol yet.
What I would try first is just sending it a virtual volume or mute key stroke.So similar to this
https://github.com/toresbe/datalink/blob/main/datalink86-captures-new.txt#L26But instead of the 0x09 at the end (digit-9) give it a try with 0x60 (volume up) or 0x0d (mute toggle). Maybe it will then leave the muted state it started up with.
6 January 2024 at 22:26 #50249 pilatomic
MemberHi,
I’m not too familiar with the DL’86, as my projects uses DL’80.
The easiest way to achieve control of your BM6500 might be to send the control codes over IR, that way you can just duplicate what your remote is sending.
7 January 2024 at 17:38 #50250B3OHACK3R
Did a quick test run today. I wasn’t able to get it out of the initial muted state as well when started through DL’86 commands. By commands on the Audio Aux Link connector I mean.
As soon as you touch a key on the remote or on the device directly it will unmute.
Sending virtual volume keys works and you can see the volume on the device is changing. Nevertheless it stays muted. The 0x0d mute command is ignored and does nothing. Maybe there is some kind of hidden command somewhere to enable the output but I couldn’t find that yet.
So if you want to stay with the cabled version maybe just try shorting the DL80 and the DL86 pins together. Then you can send a DL80 “switch on” command (which doesn’t mute the unit by default) and then switch over to DL86 for having the convenience of a more advanced protocol. Looking like sending DL86 commands into one of the DL80 connectors does trigger nothing. So any additional unit connected there might just happily ignore it. At least worth a try.
7 January 2024 at 19:24 #50251 skolesenGOLD MemberCurrently I can send and receive Datalink commands on the TV/AUX Port of the BM and I was able to retrieve commands from a MCL Sensor I bought for this Project. But unfortunately the commands only startup the BM in muted state and I can´t get it to unmute (See my post here).
Please start a new thread in order not to “hijack” Pilatomic original thread.
However it is normal behavor from the BM when it is “turned on” via MCL command. BM starts with muting speaker 1/PL and unmuting speaker 2 (MCL).
/steffen
7 January 2024 at 21:34 #50252Gspaltenhorn
BRONZE MemberPlease start a new thread in order not to “hijack” Pilatomic original thread.
Sorry this was not my intend! I started a new thread here.
But thanks for the input anyways, much appreciated!
8 January 2024 at 19:19 #50253 skolesenGOLD MemberReceived my Beotooth 5500 kit in the mail today and have assembled it.
First test om my BM 7000 was impressive. Connected with my iPhone on bluetooth with no problems.
As player I’ve tested both my iPhones own player and the spotify app with success and could control the playlist as Pilatomic have shown in his videos.
Thanks Pilatomic for a fantastic project. It gives the tape input on our beloved B&O systems a new life 🙂
/steffen
9 January 2024 at 14:52 #50254Madskp
GOLD MemberI have also received mine now and got it up and running.
Very nice and very good quality. and attention to detail for easy assembly.
I have testet it on both a Beosound Ouverture (Tape2), a Beomaster 4500 (Tape1 and Tape 2) and a MCL2AV (Tape), and from my little testing it seems to work flawless with the Beotooth 5500 activating all of the above when playing music from my phone, and also all of the systems being able to control the music (start, stop and skip) via the B&O remote and local control on the music systems.
Based on my little time with it till now I can only reccomand it.
Thanks to Pilatomic for making our old systems even more usefull 🙂
14 January 2024 at 14:11 #50255 lausviSILVER MemberI received mine almost two weeks ago, here’s finally my two cents on the product (it’s awesome!).
Here are the contents of the kit waiting for assembly:
The assembly is described in detail in the supplied manual. Basically it’s just soldering the cable (connector and PCB) and the LED and fitting it all inside the case. If you have never soldered a DIN connector it can be a bit tricky at first but that’s really the hardest part. Using a small flat-top LED and a custom 3D-printed cable holder / strain relief really shows the attention to detail of the kit (fun fact: during playback the LED flashes to match the real Beocord’s track indicator).
The finished product has a very B&O’ish style (perhaps reminding of the LC1 with a silver top and a black plastic case).
Here connected to my BM7000’s TAPE1 and showing the time display real-time on the MCP6500. I have a weak spot for the 2-way remotes and I really like how the Beotooth supports that! (This also lead me to finally building a new battery pack for my BL7000). I am also hoping to experiment using the Beotooth over MCL2 in a link room (with 2-way comms).
I had prompt replies from pilatomic and he even made two firmware updates regarding some small things I observed in my testing (difference between STOP and PAUSE commands in certain situations and a small issue with rewind/fast forward commands), so customer support was also really top notch. Also a note that not all apps that control playback over Bluetooth are not created equal (my phone’s default media app had inconsistent issues with playback controls working or not whereas my MacBook+iTunes always worked flawlessly).
This is a very useful little addition to any Datalink-equipped BM/BC. While using a Bluetooth receiver for audio on a vintage system is nothing new, the Beotooth does it well and the seemingly small addition of Datalink commands really makes it feel so much more integrated. Especially on pilatomic’s level of detail on everything.
I hope we will see more DIY-projects utilizing the Datalink bus in the future for something neat that keeps adding to the magic of B&O’s truly ageless designs.
14 January 2024 at 16:11 #50256 TignumGOLD MemberI also received the Beotooth 5500 (fully assembled) and am looking forward to give it a try on my BeoMaster 6500!
Regards, Johan
15 February 2024 at 17:35 #50257 pilatomic
MemberHello,
Quick update for those who already own a Beotooth 5500.
Firmware V1.3 is now available, with the following changes :- Fix playback not resumed when switching from Beogram to Beotooth (I was not processing that datalink command)
- Prevent transmitting AVRCP (Playback control) commands to Bluetooth player when player is not sending audio. This fixes an issue where I was listening music on my computer though the Beotooth, then switched to a headset. A few minutes later, The Beomaster would, rightfully, go to sleep, but that caused a “pause” AVRCP command to be emitted, pausing the playback. “Play” commands are still sent unconditionally, to be able to resume playback.
If you are interested to get that firmware update, contact me via private message.
In other news, I am still in contact with Microchip, diagnosing why the AVRCP Browsing feature is not working. Once that is solved, I should be able to support selecting a track by its track number directly.
