Home › Forums › Product Discussion & Questions › BeoSystem › BeoSystem AV 9000 Repair Help
- This topic has 2 replies, 2 voices, and was last updated 1 month, 1 week ago by
Philip Wong.
5 September 2026 at 13:11 #125384
Philip Wong
SILVER MemberHi, i got the BeoSystem AV 9000. It now only get power to the AV Unit itself. And shows ERROR 1 and the SW Version. Cleaning the Cable and Port didnt work. I can see the IR LED got one second glow after plugin in the tv. Any help ? or parts on the power supply i have to check ? Thanks!
5 September 2026 at 15:41 #125389moskito
BRONZE MemberERROR 1 means that the monitor cable has been plugged into the Masterlink port.
5 September 2026 at 17:14 #125396Philip Wong
SILVER MemberI played the night before and didnt unplug any cables. Monitor Port is in Control Center Port. I noticed that the status LED on the TOP of the TV isnt RED. I Did clean the Contacts.
