Home › Forums › General Discussion & Questions › General Discussion & Questions › Beosystem 72-97
- This topic has 9 replies, 5 voices, and was last updated 2 years, 9 months ago by
marc spudsy.
13 April 2022 at 02:15 #34165
matadorModeratorHi alls,
Beosystem 72-22 is a beautiful thing but far beyond my reach. It still inspired me the Unofficial Beosystem 72-97 (after the year of the speakers…).
Still missing are the 30 cm feet for the cabinet (5€ each).
In the cabinet there is an old Beosound Ouverture acting as “Center” for radio, CD, Tape and A.AUX/Phono through an RIAA preamp.
The deck is (should be!) updated with the Beolover remote control board that allows the deck to be remote controlled with an Apple remote, which IR codes are fully available for the Beo5/6 remote. Thanks to the Beo6 programming capabilities, the controls are available after selecting the phono input for the Beocenter.
Ideally, I’d like to derivate the internal tape line in to turn it into an Airplay/Chromecast input. It can be made easily with a cassette adapter but I already can hear screams !
Anyway , even if all this work fine, I had to keep it as a concept since :
1- I have no room to store away all the vintage thing that are usually standing there.
2-I’m not really satisfied with the rendering of the BL8000 vs the usual S-45-2 from the old system. Even if they (8000’s) perform better with the Beogram than with other sources.Bottom line: The Beo6 Rocks !
14 April 2022 at 18:08 #34166beosince
BRONZE MemberVery cool! Today I exchanged the plinth of my Beogram to a wallnut one, to match the recently released Beosystem 😉
2 March 2023 at 19:13 #34167 Steve at Sounds HeavenlyGOLD MemberHi matador,
I love this Beosystem! Which cabinet did you use please? Do you have any pictures with the feet added please?
kind regards Steve.
2 March 2023 at 19:48 #34168 matadorModeratorSorry, I forgot I never posted pictures with the feet. Here they are!
2 March 2023 at 20:29 #34169Madskp
GOLD MemberVery nice looking setup. I like the detail with the lamellas on the cabinet.
If you still need to connect airplay/cromecast as you mention in your first post you could always try if the 1611 coverter will give you an extra input or two
2 March 2023 at 20:58 #34170 Steve at Sounds HeavenlyGOLD MemberThanks matador,
That looks great! I have a spare Moment base unit (the tablet doesn’t work), so I am thinking about using this for streaming, with the Aux input for a Beogram. A cabinet like this could be just right….
Kind regards, Steve.
3 March 2023 at 07:32 #34171 matadorModeratorIf you still need to connect airplay/cromecast as you mention in your first post you could always try if the 1611 coverter will give you an extra input or two
The Beosound Ouverture in the cabinet as since then be replaced by a Playmaker for streaming, including radios. It drives the BL8000 but also a Beolink Passive and a pair of C40 in the back. The Ouverture you see in the pictures is just there for when/if I need to listen to a tape or a CD. And also because I have no other place to store it!
3 March 2023 at 11:09 #34172Madskp
GOLD MemberIf you still need to connect airplay/cromecast as you mention in your first post you could always try if the 1611 coverter will give you an extra input or two
Ahh then you are all covered with all sources in this setup 🙂
10 June 2023 at 19:37 #34173marc spudsy
BRONZE MemberThis is an interesting idea, one i think i will have a go at too
11 June 2023 at 16:45 #34174marc spudsy
BRONZE Membercabinet bought and built, inside, the socket unit and a beomedia 1, aux in to a turntable, room for recors and my network router (excuse the mess currently decorating, its the only bit of spare room i have to set it up)
next job cut a round disc of aluminium out of a 3mm sheet, i think thats going to be tricky
