Home › Forums › Product Discussion & Questions › BeoSound › Theatre › Beosound Theatre — Knowledge Base
- This topic has 43 replies, 29 voices, and was last updated 8 months, 1 week ago by
Bill Lumbergh.
9 March 2024 at 09:09 #39924
DHA
BRONZE MemberI have disconnection problems with my Beolab 18s – it will forget one of them (not the same one) and I have to add it back via the app. B&O suggested it was my wifi that was causing this and I should stop using 5ghz devices in the home, which isn’t possible
9 March 2024 at 09:36 #39925Marc
BRONZE MemberI tried that. Only using 2.4 wifi and the next day, gone. Both of them. Didn’t help in my case. ?
9 March 2024 at 14:32 #39926sclny1
BRONZE MemberWho are you working with to resolve these software issues? I’m working with my sales rep. He’s been very helpful. I’ve had over 10 software updates, a new Beoremote, and nothing has worked so far.
I’d be interested to know if you’re able to resolve your issues.
Good luck!
20 March 2024 at 13:10 #39927jptinglev
BRONZE MemberPlease be adwised – do not update you Apple TV4 (IF YOU HAVE connected BST over the HDMI).
you will lose control from you BeoremoteOne.
problem ist the Apple TV uodate 17.4
i have had a short conwesation to the support team on the topic – no solution for the moment being!
sorry for the danish feedback form the support team – see below:
Response By Email (18/03/2024 12.08 PM)
Hej Jens,
Tak for din henvendelse.
Når dit AppleTV ikke længere reagerer på Beoremote One, er det sandsynligvis, fordi Apple har begået en fejl ved seneste opdatering til version 17.4. Hvis dit AppleTV ikke er udstyret med et IR-øje, forgår betjening af AppleTV med Beoremote One via CEC og CEC fungerer ikke efter denne opdatering.
Hvis dit AppleTV er udstyret med et IR-øje, skal vi lede efter fejl et andet sted.
Vi regner med, at Apple løser problemet meget snart, men indtil da, er det kun muligt at betjene AppleTV med dets egen fjernbetjening.
Med venlig hilsen
Sussi | Customer Care
20 March 2024 at 23:14 #39928 MillemisBRONZE MemberIn addition.
For those who do not understand the danish answer from Sussi….
…..this is only in case you have relied on CEC for controlling.
Those who have control via PUC haven’t got this problem.MM
21 March 2024 at 11:45 #39930 MillemisBRONZE MemberGood afternoon! What is the difference between CEC and PUC? How is PUC control implemented? CEC, as far as I know, is implemented programmatically in HDMI, starting with version 1.4 (ARC), including the latest modification of eARC in version HDMI 2.1. What is needed to connect via PUC?
PUC is a method invented by Bang & Olufsen to control external devices, that are connected to a Bang & Olufsen tv (solution), with a B&O remote.
Read about it hereThe origins of PUC goes back to the 90’ies and was previous called STB controlling.
Read about that hereApart from the signal cable – nowadays the HDMI connection – you will need an ir-blaster attached to the external device and connected to the ir-connection port on the BV (or most recent to the Beosound Theatre).
You can see a video about PUC here – in this example you see the BV11.
In the ‘old days’ the needed codes had to be loaded via cable to the BV’s from a B&O technician – since modern BV’s are online, these codes can be downloaded directly from a B&O server and installed.
21 March 2024 at 13:04 #39929Vedet
22 March 2024 at 16:14 #39931Vedet
BRONZE MemberThank you so much)) Now everything has become clear.
1 April 2024 at 07:16 #39932cklit
ModeratorQ: How do I setup a Listening Position for (2.0) music listening on Beosound Theatre?
A: Here is what I would do: I have a 5.0.2 setup (Theatre+Fronts+Surrounds+Front heights). If this was a Beovision Eclipse or 11 or similar and I wanted a listening position for music listening, I would probably create a dedicated 2.0 speaker group, where only the Front speakers were added. However, because bass management in Theatre works differently (all speakers play their part in the low frequencies based on their capability), I do it differently here.
1: I’ll start by setting up and adjusting a Listening Position with all speakers, optimized for the sweetspot.
2: I’m lucky enough to have a room that allows for “the triangle”, so that I can sit perfectly in the middle of the 2 fronts at the same distance from each speaker, as the distance that the fronts are apart. Therefore, after the microphone measurement, I check that the distance to each front is set to the same (because I don’t want to mess with the timing between the 2 fronts, when I know I’m seated in the optimal position). While I’m at it, I check all the other distances too
3: Once the Listening Position with all speakers is perfectly tweaked, go to your desired Sound mode and ensure that the processing is set to ‘Direct’. Leave ‘Bass management’ ON. This way ALL your speakers are helping with the low end, even though it’s only the fronts that are playing everything above 120Hz.
Now you won’t hear large differences in bass performance, e.g. when switching from a movie in surround to music in stereo – AND you’re utilising the full performance of your carefully collected entertainment system.
Just to recap: If I only have one seating position, I can limit myself to 1 Listening Position with all speakers included, and 2 sound modes; one in Direct mode for music, and one in True Image for movies (my own preference, use something different if you like). Obviously, you may need a listening position optimised for more people, but that is kind of out of the scope of this question. Remember that you can assign a specific sound mode and listening position to each individual source via the app, so that you don’t have to change manually each time.
Enjoy the music 🙂
2 April 2024 at 18:13 #39933beomedia
BRONZE MemberWorked as you described – thanks for sharing. This way the Theatre is contributing with its bass drivers even when playing in stereo with connected speakers.
16 April 2024 at 08:35 #39934Orsten
BRONZE MemberI have the following problem with my Theater and would be happy if you could try it out.
With the following title and video, the left woofer on the back of the device rattles audibly. All set to factory settings with room correction.
Title: Beg Forgiveness by Kanye West from second 13
Video: Dolby Atmos Fallout season 1 episode 1 from minute 6:10B&O in Berlin have been able to reproduce the same problem in 3 theaters. So it seems to be a technical problem.
Regards
Translated with DeepL.com (free version)
17 April 2024 at 02:33 #39935johnbrks
BRONZE MemberI occasionally have the problem with my BS Theater where it does not recognize the AppleTV. This happens spontaneously. Unplugging the theater does not fix the issue. If I press play, the Theater displays ‘Loading. Please try again later”.
The Television (LG G series is fine) and plays AppleTv fine and the speakers are fine.
Any suggestions?
it seems reset to factory will fix it, but resetting everything is annoying.17 April 2024 at 10:56 #39936solidkd
BRONZE MemberMy BST cant rename in the app,every time renamed it will return to beovision theatre,does anyone experience this bug?
17 April 2024 at 18:16 #39937 Severed_hand_of_skywalkerBRONZE MemberI have the same problem with my A9 Gen 2. Refuses anything but its original name.
13 June 2024 at 12:12 #56462griebel
GOLD Member- Hi,
Is there a guide to pair a Bluetooth headphone to the BeoVision Theatre? Doesn’t seem to be straightforward.
ThanksGuy
26 June 2024 at 18:18 #57011Sandyb
BRONZE MemberQuick note – there is an updated version of the Theatre Speaker Setup – Best Practices document (a V2).
They’ve added a page for setting up for stereo listening.
Additionally they’ve removed the role/allocation tables for non-Atmos content, and the mention of “For content that does not include height-channels, you can create a Listening Position without any height-roles. This may be preferable. See Table”
No idea why its been removed, nor whether the previous guidance is no longer relevant.
Anyway, the guide is on Discord (under Documentation).
6 September 2024 at 05:17 #58917David Sentance
BRONZE MemberCan the Theatre accept a DSD signal or will it need to be converted to PCM first?
14 February 2025 at 04:59 #63777per.ivarsson
BRONZE MemberHi, I’m new to the forum, as well as a new Theatre owner. What is the name of the Discord group where I can find this document?
14 February 2025 at 10:54 #63778 MillemisBRONZE Member@David
It needs to be PCM.
Unlike the Beoworld Forum Discord/(the group there/Beotalk and B&O) is a closed forum….you’ll need an invite.
If you watch the Beotalk YT show, you probably can get an invite from Miki.MM
15 February 2025 at 02:38 #63801per.ivarsson
BRONZE MemberThanks Millemis!
