Home › Forums › General Discussion & Questions › General Discussion & Questions › Beosound Ouverture – CD with strange behaviour
- This topic has 5 replies, 2 voices, and was last updated 12 hours, 57 minutes ago by
23 March 2025 at 16:47 #64635
Marto
BRONZE Member- Hello to everyone. Recently I bought a second hand Beosound Ouverture with problem with the CD. The version is with CDM12 mechanism. When the disc is inserted it starts spinning without stopping, but on the display stay only CD and donโt start any track. I start reading here in the forum all topics with similar issues. This is what I do for the moment:
1. Changed the SMD capacitors with tth on the Servo PCB.
2. Test mode the CD – all passes fine with no errors.3. Deep clean the laser unit
4. check for bad soldering, wiring and ribbon cable.
The laser light is good, focus is working, all the motors working and still not playing any CD.
Also when digging information, I found some modifications that were made in the past on the Servo board. A resistor was added on one place, also one capacitor. I donโt know why? I removed them and test with no success.
I am into dead end. I will appreciate any advice.
ThanksMartin
You must be logged in to view attached files.23 March 2025 at 21:53 #64644ModeratorI am not sure whether you have the service manual (avail on Beoworld to Silver and Gold Members), but the following extract may well explain the extra resistor and capacitor (Edit – possibly/probably another resistor?), and can I see a surface mounted diode (green LED?) in the second picture?ย Is pin 6 of 8IC1 still short circuited to ground?ย If so you may wish to revert and try again.
This reply was modified 1 day, 11 hours ago by
Location: Warwickshire, UKMy B&O Icons:24 March 2025 at 06:17 #64649Marto
BRONZE MemberThanks for the reply Guy, but unfortunately mine is with CDM12 ( new version) and I donโt have pcb 8. I have pcb89, which is on the place of pcb8, but very different schematic. I have all of the service manuals. On that pcb89, Iโve checked the transistors, voltages and cable slots for connectivity. Everything looks fine. I will attach a photo of that board in case you want to see it. Also i will add a photo of the laser to tell me if this kind of light is normal.
You must be logged in to view attached files.24 March 2025 at 18:57 #64675ModeratorAh yes, sorry I can see that now when I read the whole manual!
B&O has had a habit in the past of making late modifications to PCBs by adding such components, but I doubt that they would do so for such a relatively modern element that should work as designed.
My most relevant CD repair experience is all detailed in this thread, but the CD on my BC2300 was CD Pro rather than CDM12:ย https://forum.beoworld.org/forums/topic/beosound-ouverture-cd-not-working/#post-50375
Location: Warwickshire, UKMy B&O Icons:24 March 2025 at 19:19 #64676Marto
BRONZE Member<p style=”padding-left: 40px;”>I read all the threads in this forum and many others ๐. ย Maybe I have a progress today. I read a thread for CDM12 lasers and found that laser diode can be partially detached and clean. When I open mine today, I found some kind of spot on the glass (not sure what real material is) and I think that is like a little burnt out (I will attached a photos). ย Maybe this will be the reason not start playing. I already order a new laser and when it arrives I will change it and hopefully resolve the issue. Thanks again for your support.</p>
You must be logged in to view attached files.24 March 2025 at 20:37 #64691ModeratorYes that does look strange, but if there is a problem I am surprised that it passes all the Test Modes.
I look forward to hearing whether a new laser cures the fault.ย Fingers crossed!
