Home › Forums › Product Discussion & Questions › BeoSound › Beosound Level
- This topic has 2 replies, 2 voices, and was last updated 3 years, 12 months ago by
Csaba.
2 April 2022 at 03:43 #33776
jk1002
BRONZE MemberSo I was eying the Beosound Level for a while but held back since it would not integrate with my Essence pending Software upgrade.
I lost a bit track but the US site is still talking about pairing with chromecast and airplay. Did that rumored update nor materialize?
Other question I have, I would want the google less version, Is pairing 2 in Stereo working nowadays, specifically with Spotify Connect?
Best
JK
2 April 2022 at 07:58 #33777 Csaba
BRONZE MemberHi JK,
I’ve tried to link in YouTube links that the forum didn’t allow to post here.
The Level now supports:
– Spotify Connect
– stereo-pairing using the native B&O app (note that you need two of the same version, so either two Levels with Google Assistant or two without)
– Beolink Multiroom using the native B&O app, so you can now connect to your other B&O devices that are pre-Mozart and Beolink-enabled.
My two non-GA Balances that I have work flawlessly both in multiroom and stereo (as you probably know the Balance like the Level uses the Mozart platform).
2 April 2022 at 14:43 #33778 Csaba
BRONZE MemberHi JK,
I myself have two Balances which use the same Mozart platform as the Level and while I don’t use Spotify a few months ago B&O released a big Spotify Connect update so I think it should be supported on the Level now. I’d say it should work in stereo even if the B&O website doesn’t mention it specifically here other than that the Level supports Spotify Connect:
John from B&O Manchester gave an update on the latest way to stereo-pair Mozart products here so that I know from my Balance works with the Level:
B&O Manchester also sums up the other recent big software update that enables Beolink multiroom as well:
So I think it is very likely that you can now do all those things.
Anybody that can confirm?
