Home › Forums › Product Discussion & Questions › BeoSound › Beosound Core – Optical-In to TV not working
- This topic has 6 replies, 3 voices, and was last updated 2 years ago by
Millemis.
3 April 2024 at 03:26 #54069
Paul Jordan
BRONZE MemberHi B&O Dreamers,
I have a setup (see below) including a Beosound Core as end piece to a TV via an Optical cable, but no sound comes out of the BL18 speakers. Any ideas how to make it work?
I tried to change the source on the B&O Mobile App to Optical-In and still no sound.[BL 18] via WiSA << Transmitter 1 >> [BL 18] via WiSA
PowerLink RJ45
Beosound Core
Optical-In
TV3 April 2024 at 19:26 #54070 MillemisBRONZE MemberDid you set the sound of the tv to PCM/stereo – and to output from Toslink – in the settings there.
Please be aware!
Depending on the tv brand this might be named differently in the settings.MM
4 April 2024 at 06:56 #54071Paul Jordan
BRONZE MemberIn my case, I connected the SONY TV to the Transmitter 1 and the TV automatically switches to Optical output and plays sound. Using Transmitter 1 is not option because I could not lower the minimum volume which is too high. The Optical out min volume could not be lower by the TV too.
But if I switch to the Beosound Core, no sound comes out.7 April 2024 at 19:13 #54072Paul Jordan
BRONZE MemberThe Beosound Core actually has only Optical-Out port.
Topic to be closed…
7 April 2024 at 22:05 #54073 MillemisBRONZE MemberThe Beosound Core actually has only Optical-Out port. Topic to be closed…
Really?
8 April 2024 at 20:30 #54074 lesbartSILVER MemberThe Beosound Core actually has only Optical-Out port. Topic to be closed…
Isn’t it optical INPUT?
8 April 2024 at 22:45 #54075 MillemisBRONZE MemberSure – that is the combined analog/digital input port, that is available on many ASE-based devices.
Just to prove that Paul Jordan was wrong ? about the BS Core.
