Home › Forums › Product Discussion & Questions › BeoSound › Beosound Century – ‘Button’ Troubleshooting
- This topic has 4 replies, 3 voices, and was last updated 1 year, 5 months ago by
woodewood.
14 October 2024 at 22:09 #60151
woodewood
BRONZE MemberHi All
I bought my Century from new when it first came out and have had many years of total reliability, it’s always been mounted in walls so minimal moving (except house moves basically).
We’ve mainly used it with remote controls which have worked perfectly, however I now have a problem with the buttons themselves, all the functions work perfectly with the remote (so we can use it) but when you press any of the buttons physically there is no response.
Can anyone please suggest or help with a fix to this?
Regards
woodewood
15 October 2024 at 09:37 #60161 peppsModeratorHi Woodewood,
Very odd behaviour. If it doesn’t make any difference to power it down for ten minutes and restart, I would expect an electronic element has expired.
It might be time to find a trusted service centre and have it inspected.
Favourite Product: Beosystem 6500
15 October 2024 at 09:52 #60163woodewood
BRONZE MemberThanks Pepps
After I posted this last night, I sprayed the ‘button’ panel (and as far behind as i could get) with Isopropyl Alcohol 824 spray. After allowing to dry off. After letting it sit for an hour, all the buttons started to work physically again and did so until I turned in for the night.
This morning when I returned, it was as before, the buttons has stopped working?
If you or anyone else have any further suggestions that would be fabulous. But if not then I’ll take up your suggestion and take it to a trusted service centre (anyone know anywhere around Gloucester?).
James
15 October 2024 at 16:03 #60166 GuyModeratorThere’s a video explaining how to dismantle the BS Century here:
And if you go to about 9 mins 30 secs you will see the little display board being removed. It is only connected by a little white 9-pin connector, so perhaps this has come loose or has a bad/corroded contact? I would avoid spraying any more IPA because this could easily cause problems elsewhere.
If the connector is not at fault, you may be able to strip down the display/button board further, or look for a replacement.
EDIT: Sometimes these videos can be a little ‘hit and miss’. The Service Manual is available on Beoworld to Gold/Silver forum members but I had a look and it is of limited help in this instance, except to identify components.
15 October 2024 at 17:17 #60172woodewood
BRONZE MemberHi Guy
Thank you so much for this, I will get onto this and strip it apart – you are right about the IPA, the tape deck did not like it (no transmission to the tape rollers now), i’ll take a look at this too when I’ve stripped it down!.
I’ll let you know how I get on!
Regards
James
