Home › Forums › Product Discussion & Questions › BeoSound › Beosound 9000 with 3x BeoLink Passive zone issues?
- This topic has 29 replies, 6 voices, and was last updated 5 months, 2 weeks ago by
James Powell.
9 February 2023 at 10:52 #43630
luck6k
BRONZE Membermain unit Beosound 9000
main zone 1x Beolink passive via powerlink
2 rooms
2x BeoLink Passive with BeoLink IR receiver via Masterlink
main room works fine.
issue I have is If both Beolink passive are plugged in with masterlink then one of them is not responding to beolink ir receiver (eye)
if i unplug one of them other one does works fine.
that got me into thinking reprogramming eye with beo4 remote with no luck atm
as i said if all is plugged in then one is working 100% and other remote lights coming on but not responding – play button stays RED after pressing it.
any ideas?
9 February 2023 at 14:02 #43631 GuyModeratorHi and welcome to Beoworld!
Have you tried swapping the IR sensors between the two passives, to see if the fault follows?
I would suspect cabling of one of the IR eye’s to be either incorrect or disconnected, either inside the sensor itself, or inside the DIN connector.
9 February 2023 at 14:18 #43632luck6k
BRONZE MemberHey Guy
yes tried that if I plug IR sensors alone they work in both amps but if they both connected then one doesn’t work.
one guy that does work with B&O suggested program eye via boe4 tried that with no luck so far. its like its not switching to input or source. https://share.icloud.com/photos/0beSPkFx2lgbK2WGc-l0QIf3w
9 February 2023 at 14:34 #43633 GuyModeratorMaybe try checking the ML connections:
- Power down the complete system (unplug from mains, including main room BS9000 and Passive).
- Unplug all the ML connections.
- Make sure all the ML plugs are clean and undamaged and that there is no dust or fluff inside the sockets.
- Reconnect the ML cables
- Power the system up again.
- Re-do the option settings (put the main room in A.OPT 1, and each link room in L.OPT 6). If you need instructions for this, let me know.
Then try control again.
9 February 2023 at 14:36 #43634 GuyModeratorA further thought: In the main room is the ML cable connected directly to the BS9000?
(I only ask this because you have a Passive in the Main Room, but I assume that this is just acting as an amplifier and should only be connected to the BS9000 by a Powerlink cable)
9 February 2023 at 14:57 #43635luck6k
BRONZE Membercorrect passive in main room connected from bs9000 by powerlink acts as amp…
ML is direct from bs9000 to both or passives in other room. when only one is plugged in that room works when i plug 2nd one only one works. if i only plug 2nd one 2nd one works with no issue. I think its going to be something to do with L.OPT… I’ll try tmr nights
1 June 2023 at 19:06 #43636QuentinLJ
BRONZE MemberHi in my personal use I try to use the Beolink passive with the powerlink but its no work, do you know if I need to program the Beolink passive with Beo 4?
1 June 2023 at 19:18 #43637 GuyModeratorHi in my personal use I try to use the Beolink passive with the powerlink but its no work, do you know if I need to program the Beolink passive with Beo 4?
This should work fine without any programming of the Passive. Make sure that nothing is connected to the ML socket or IR socket of the Passive, and you should also use a fully wired MK2 PL cable.
EDIT: I just saw that both Steve and Matador had commented in the other thread – at least we are consistent with our advice!
6 November 2025 at 09:18 #70957James Powell
BRONZE MemberHi,
I have a similar issue. I have a 9000 connected to a passive and ir eye. The IR eye and passive were working fine.. then… I used my BEO5 to turn on my Samsung tv. After this my eye no longer responds to the remote or touch (ie using the buttons on the eye). I have unplugged everything a million times and replaced the cable for the eye. Any ideas? Thanks
6 November 2025 at 18:37 #70959Madskp
GOLD Memberthen… I used my BEO5 to turn on my Samsung tv. After this my eye no longer responds to the remote or touch (ie using the buttons on the eye)
I would not suspect the use of a BEO5 remote to have changed anything.
Are you using the BEO5 remote for the room with the Beolink Passive or do you have another B&O remote in that room?
10 November 2025 at 08:24 #71019James Powell
BRONZE MemberI also have a beo4 remote which I prefer to use. Bizarrely, the IR eye will not respond to either remote however, if I hold done the red “off” button on the remote for about 5 seconds the red light on the IR eye blinks..
10 November 2025 at 17:30 #71026Madskp
GOLD MemberI also have a beo4 remote which I prefer to use. Bizarrely, the IR eye will not respond to either remote however, if I hold done the red “off” button on the remote for about 5 seconds the red light on the IR eye blinks..
One thing that could have happen in the link room is that the option settings was changed and affects how it receives IR commands. You can try to set the option for the link room again with the BEO4 by following this procedure:
- Be sure that the entire system is in standby
- Hold down standby + list on the BEO4
- The text in the display should change.
- Press the list button until OPTION is shown in the display and press GO
- Press list until LINK is shown in the display, then press 6 and GO
- The red LED on the IR eye should blink once to confirm it has received the change
Try to see if this makes a difference
10 November 2025 at 19:02 #71041James Powell
BRONZE Memberthe led blinked during the process but still no response to other commands. thanks again for your advice Madskp
11 November 2025 at 06:08 #71058Madskp
GOLD MemberHard to say what it could be then
Do you have any other link rooms and are they working?
11 November 2025 at 07:55 #71060James Powell
BRONZE MemberNo. I have tried rewiring everything many times. The passive is in the same room as my 9000 but it didn’t affect it previously. I can only think it is an issue with the master link cable not sending a message from the passive back to the 9000?
11 November 2025 at 14:05 #71064Madskp
GOLD MemberThe passive is in the same room as my 9000 but it didn’t affect it previously
Ok, just to be sure do you also have speakers connected to the BS9000 or only to the passive?
If you have speakers on both could you control them separately before?
11 November 2025 at 17:37 #71078James Powell
BRONZE MemberI have attached some beolab 3 to the 9000 and they work fine.
11 November 2025 at 17:47 #71079Madskp
GOLD MemberOne more follow up question. When it worked did both the 9000 and the Beolink Active start when you activated a source like CD?
12 November 2025 at 08:49 #71105James Powell
BRONZE MemberNo, I could use them independently of each other. I ultimately disconnected the beloabs. It is a mystery eh!
12 November 2025 at 09:34 #71106Madskp
GOLD MemberCan you explain how you used them independently. If you were to play a CD for example. I asume you would have to use an other command for one of the zones?
