Home › Forums › Product Discussion & Questions › BeoSound › BeoSound 9000 MK3 + Klipsch The Sevens via Powerlink to RCA – No Sound
- This topic has 0 replies, 1 voice, and was last updated 4 months ago by
Seungman Han.
Viewing 1 post (of 1 total)
17 June 2026 at 14:25 #124053
Seungman Han
BRONZE MemberHello everyone,
I am trying to connect my BeoSound 9000 MK3 to a pair of Klipsch The Sevens powered speakers.
My setup is:
BeoSound 9000 MK3 Powerlink output
→ Sounds Heavenly 5-pin DIN to twin RCA Powerlink compatible cable
→ Klipsch The Sevens RCA input (set to LINE mode)The BeoSound 9000 is working normally and CDs play correctly.
The Klipsch The Sevens are also working correctly with other sources.
However, I get no sound at all through the Powerlink connection.
I have tested both Powerlink sockets on the BeoSound 9000 with the same result.
My questions are:
- Should this setup work directly with a BeoSound 9000 MK3?
- Do I need a Speaker Sense Adapter?
- Is there any Option Programming required?
- Is there anything else I should check?
Thank you very much for any advice.
