Home › Forums › Product Discussion & Questions › BeoSound › Beosound 9000 mk1, mk2, mk3 data-link
- This topic has 8 replies, 4 voices, and was last updated 3 years, 7 months ago by
Guy.
13 August 2022 at 06:43 #36972
Jg1976BRONZE MemberSo mk2 & mk3 do not have data-link on the Aux input as I understand. But how about mk1? I have an ouverture where I can control an beogram 4500 (record player) via remote, also step back & forth via remote. Is that possible on beosound 9000 mk1 while connecting via aux input (and select PHONO)? Anyone knows?
13 August 2022 at 20:57 #36973 MillemisBRONZE MemberNone has datalink – as far as I know.
13 August 2022 at 23:06 #36974 Jg1976BRONZE MemberThank you Millemissen. That makes ouvertyre quite rare does it not?
14 August 2022 at 09:25 #36975 MillemisBRONZE MemberSure….that is well known (amongst those in need of datalink).
In retrospect it is a pity, now that the Beogram/vinyl players have become so popular.If you don’t need Masterlink, you could however, use the Phono socket on one of the older Beomasters (3500/4500/6500/7000 etc).
Also see:
https://www.beoworld.org/article_view.asp?id=64
14 August 2022 at 10:04 #36976 GuyModeratorI think that the early BS9000 may have datalink. The service manuals on site show datalink present in the Mk1 (Types 2521 to 2530), but not present in the Mk2 and Mk3. However, B&O service manuals have been known to be wrong in the past.
I think datalink was dropped from most products as N.RADIO and N.MUSIC compatible products were introduced, such as BS3000/3200. N.RADIO used the old PHONO IR command.
The early BS9000s Mk1 were not N.RADIO/N.MUSIC compatible, hence required a SW upgrade. Perhaps such a SW upgrade disables the datalink capability.
14 August 2022 at 11:19 #36977 MillemisBRONZE MemberInteresting….worth investigating!
Anyone with a MK1 here to test it?
14 August 2022 at 14:04 #36978 carolpaBRONZE MemberI think that the early BS9000 may have datalink. The service manuals on site show datalink present in the Mk1 (Types 2521 to 2530), but not present in the Mk2 and Mk3. However, B&O service manuals have been known to be wrong in the past. I think datalink was dropped from most products as N.RADIO and N.MUSIC compatible products were introduced, such as BS3000/3200. N.RADIO used the old PHONO IR command. The early BS9000s Mk1 were not N.RADIO/N.MUSIC compatible, hence required a SW upgrade. Perhaps such a SW upgrade disables the datalink capability.
I bought my first BS9000 while it was introduced to the public. Even this mkI version did not support datalink on the AUX.
14 August 2022 at 15:06 #36979 Jg1976BRONZE MemberThank you coralpa!
I thing that cleared up the question!
Will keep my ouvertyr for a while…14 August 2022 at 15:19 #36980 GuyModeratorEven my (gen 1) BeoSound 1’s service manual shows the AUX datalink pins connected to its processor. As I said, there seem to be several errors. (BS3000 service manual likewise)
I would quite like to control my BG6500 via my BeoSound 1 ?
