Home › Forums › Product Discussion & Questions › BeoPlay › Beosound 5 settings
- This topic has 4 replies, 2 voices, and was last updated 4 years, 4 months ago by
Ipe.
4 May 2022 at 10:23 #34584
Ipe
BRONZE MemberHi,
Have problems with Beosound 5 setting.
I can just have the normal ones like sound but if I want to go further……no.
Other thing is that I can’t see configuration menu from BV9.
TV detects Beomaster and I can adjust volume but that’s all.
Also could not download Beoconnect program to MacBook. “untrusted”
4 May 2022 at 11:58 #34585NQVHNWI
BRONZE MemberHi,
Im a bit rusty on BS5 settings with ML TVs. Hopefully this will give you pointers to self-diagnose.
- BeoSound 5 / Beomaster 5
Connection Audio
BeoSound 5 can be placed in a setup, where either BS9000, BC2, BC2AO,
BS3200 or BS4 is used as audiomaster and BeoSound 5 is used
for N.MUSIC and N.RADIO.
Audiomaster YES/NO on BeoSound 5 must be set to NO in this setup.
This will disable OPTIONS setting for the BeoSound 5.
The OPTION setting, referred to in this conclusion refers to
the Audiomaster.
Selecting option on the audio master
Option: AUTO configurating (option 0)
********************* AUDIO/VIDEO/LINK SYSTEM SETUP *******************
Connection
Connect the Master Link socket of the audiomaster to the MASTER LINK
socket of the TV-set using a BeoLink cable.
********************* REMOTE CONTROL FOR MAIN ROOM ********************
The recommended remote control is Beo4
The following remote controls may also be used:
Beo5
Setup for Beo4 remote control:
Beo4’s “LIST” must contain the following items in order to be able
to operate the Main Room products.
- You will not see the BS5 on the TV. However, you will get Beomaster5 contents on N.Music or N.Radio
- Connect Beolabs to the TV PL outputs and not the BS5
4 May 2022 at 13:17 #34586Ipe
BRONZE MemberOk…………but how about those system settings?
How to go there? I can just setup volume, balance etc .
On system settings I just get “language”and “time zone”
There should be some way.
4 May 2022 at 14:03 #34587NQVHNWI
BRONZE Member4 May 2022 at 16:35 #34588Ipe
BRONZE MemberWell………not working. No service settings available.
Seems also that volume etc. settings not there. If I shut down the whole thing
and take the mains totally off for awhile and restart then settings are available except
those service settings…….:/
