Home › Forums › Product Discussion & Questions › BeoSound › BeoSound 5 screen dead?
- This topic has 4 replies, 2 voices, and was last updated 3 years, 9 months ago by
griebel.
30 May 2022 at 05:08 #35168
griebel
GOLD MemberHi,
I have been using a BM5/BS5 combo for many years. While the motherboard and the HDD of the BM5 have been replaced a couple of times, the BS5 unit worked fine until recently.
There is no display anymore on the BS5 or occasionally the display shows weird blinking images. I still can hear the click sounds when turning the wheel. Of course, I checked the DVI cable which seems OK as far as I can tell.
Any idea on how to determine what part of the BS5 is defect (LCD display, motherboard, mainboard…)?
Thanks.
13 June 2022 at 20:47 #35169ethuijs
BRONZE MemberHi Griebel, as the BM5 is just a XP PC may try to connect an PC screen to the BM5. I think its DVI connection but follow the cabling from the BS5 and you will find the connector. A harddisk failure could also be the problem. On the old forum fixes for replacement of the HD are documentend. Kind regards, Edwin
18 June 2022 at 21:45 #35170griebel
GOLD MemberThe BM5 works fine with a new HDD. It’s the BeoSound5 that has a dark screen. Replaced the DVI cable with a new one; didn’t help.
20 June 2022 at 15:44 #35171ethuijs
In the Netherlands a screen is for sale.
Regards, Edwin
20 June 2022 at 20:18 #35172griebel
GOLD MemberThank you. I will definitely look at this offer.
