Home › Forums › Product Discussion & Questions › BeoSound › Beosound 5 option question
- This topic has 10 replies, 5 voices, and was last updated 14 hours, 48 minutes ago by SaltineSurfer.
26 March 2024 at 10:48 #53833
What option setting is recommended for a BS5, that is not connected to MasterLink and has no speakers connected to it? Only use is the line out connection to a ML/NL converter?
Thanks!
27 March 2024 at 20:28 #53834Hello Razlaw, I would say option 1? The only ‘no speakers connected’ setting is 0, but that is disabling IR remote control. Apart from Option 1, all settings are meant for a MasterLink setup in my view.
“The music system has five different Option settings:
Option 0. Used when your music system is connected to your video system and no speakers are connected directly to your music system.Option 1. Used when your music system is set up on its own or connected to a video system, when speakers are connected to your music system.
Option 2. Used when your music system is set up in one room and connected to a video system set up in another room.
Option 5. Used when your music system is set up in a link room which also comprises a Bang & Olufsen television.
Option 6. Used when your music system is set up in a link room without a Bang & Olufsen television.”
Regards, Johan
PS – why not ML connect it to a BLC and enjoy control from other devices?
Location: Netherlands28 March 2024 at 15:06 #53835Thanks! Your thoughts are just what I had come up with experimenting and looking at the manual.
I am not connecting it by ML for two reasons. First, I have a Beosound 3000 connected by ML but it does not have the newer software chip to function well with a BS5 also connected. Have spent many hours trying to get both to work together well. The BS3000 would need a new chip with Option 5. Second, having N Music available both from NL and Mozart products and the BS 5, I thought might cause problems…..although as I type this it occurs to me I could rename N. Music on the BS5 as well as N. Radio. The BS 5 has pretty much been a wall decoration for years. If connected with Line In I can at least feel like it is functioning part of the system and listen to the music stored on it occasionally if I want to.28 March 2024 at 15:26 #53836Seems a cool idea – definitely worth trying out.
I guess that the line out is at fixed volume, since it was used for a connection to a tv (integrated setup), where the volume is controlled.
The line-in of the converter has auto sense, if I remember correctly.Looking forward to hear about your findings.
Location: Flensborg————Danmark28 March 2024 at 17:18 #53837Connecting the BeoSound 5 to the Line In on the converter works fine, with one exception. I can not join Mozart products, only older NL products. What makes it weird is I can join my BS3000 through the converter to Mozart products.
I have Beconnect Core ordered. I am sure if I connect the BS5 to the line in on it, it will all work. I will probably try it although the intended use for the BCC is to use with my BL1s.29 March 2024 at 07:44 #53838I have a Beosound 3000 connected by ML but it does not have the newer software chip to function well with a BS5 also connected. Have spent many hours trying to get both to work together well. The BS3000 would need a new chip with Option 5. Second, having N Music available both from NL and Mozart products and the BS 5, I thought might cause problems…..although as I type this it occurs to me I could rename N. Music on the BS5 as well as N. Radio.
Hi Razlaw, my thought was to introduce a second BLC: one for the BS3000 and one for the BS5, both A.Slave. That should allow to ‘filter’ the audio sources you want to have ‘mapped to NL’. And maybe solve your Line In / Mozart problem?
In my (non Mozart) set-up I do the same: I have one BLC feeding BS5 N.MUSIC into NL, and one feeding BS6500 CD into NL. Works well.
Just to be sure! Hope this helps, regards, JohanLocation: Netherlands29 March 2024 at 11:59 #53839What sort of control do you have the BS 5 with that option?
29 March 2024 at 13:08 #53840Hi Razlaw, I can start/stop the BS5, go to next/previous song, instruct a new MOTS seed, access colored favourites, select internet radio stations from preset list. So basic control. In my case the BS5 is in the office/attic where I use it mainly. But in the kitchen/living I often listen to BS5 N.MUSIC and let it MOTS on. I am discovering songs in my own collection that I sofar never really listened carefully to! And I enjoy knowing that my B&O kit is maximally integrated. Regards, Johan
Location: Netherlands29 March 2024 at 17:12 #53841Thanks! I will consider another converter. Today I connected the BS5 to line in on a Core. That does allow it to be distributed to all products, Mozart included. Of course can only control it in the room where it is located.
30 March 2024 at 17:52 #53842Hello Razlaw, I would say option 1? The only ‘no speakers connected’ setting is 0, but that is disabling IR remote control. Apart from Option 1, all settings are meant for a MasterLink setup in my view. “The music system has five different Option settings: Option 0. Used when your music system is connected to your video system and no speakers are connected directly to your music system. Option 1. Used when your music system is set up on its own or connected to a video system, when speakers are connected to your music system. Option 2. Used when your music system is set up in one room and connected to a video system set up in another room. Option 5. Used when your music system is set up in a link room which also comprises a Bang & Olufsen television. Option 6. Used when your music system is set up in a link room without a Bang & Olufsen television.” Regards, Johan PS – why not ML connect it to a BLC and enjoy control from other devices?
In my opinion with the proposed use of the BS5, only if the option 0 is chosen will make a difference in a day to day use (of course under the condition there are no other ML device in the same room and/or ML and NL devices listening to IR commands)
4 February 2025 at 16:31 #63400Hi Razlaw, I can start/stop the BS5, go to next/previous song, instruct a new MOTS seed, access colored favourites, select internet radio stations from preset list. So basic control. In my case the BS5 is in the office/attic where I use it mainly. But in the kitchen/living I often listen to BS5 N.MUSIC and let it MOTS on. I am discovering songs in my own collection that I sofar never really listened carefully to! And I enjoy knowing that my B&O kit is maximally integrated. Regards, Johan
Hi Tigum, do you have your BS5 connected to an NL/ML converter? If so, how are you instructing the MOTS playback? I’ve not yet figured out a way to do this from an NL speaker such as A9 or BS2, via the beoremote 1 or b&o app. Holding down play doesn’t work like it does from masterlink speakers. Many thanks. Rob.
