Home › Forums › Product Discussion & Questions › BeoSound › Beosound 5 option question
- This topic has 11 replies, 5 voices, and was last updated 1 year, 2 months ago by
Tignum.
26 March 2024 at 10:48 #53833
Razlaw
BRONZE MemberWhat option setting is recommended for a BS5, that is not connected to MasterLink and has no speakers connected to it? Only use is the line out connection to a ML/NL converter?
Thanks!
27 March 2024 at 20:28 #53834 TignumGOLD MemberHello Razlaw, I would say option 1? The only ‘no speakers connected’ setting is 0, but that is disabling IR remote control. Apart from Option 1, all settings are meant for a MasterLink setup in my view.
“The music system has five different Option settings:
Option 0. Used when your music system is connected to your video system and no speakers are connected directly to your music system.Option 1. Used when your music system is set up on its own or connected to a video system, when speakers are connected to your music system.
Option 2. Used when your music system is set up in one room and connected to a video system set up in another room.
Option 5. Used when your music system is set up in a link room which also comprises a Bang & Olufsen television.
Option 6. Used when your music system is set up in a link room without a Bang & Olufsen television.”
Regards, Johan
PS – why not ML connect it to a BLC and enjoy control from other devices?
28 March 2024 at 15:06 #53835Razlaw
BRONZE MemberThanks! Your thoughts are just what I had come up with experimenting and looking at the manual.
I am not connecting it by ML for two reasons. First, I have a Beosound 3000 connected by ML but it does not have the newer software chip to function well with a BS5 also connected. Have spent many hours trying to get both to work together well. The BS3000 would need a new chip with Option 5. Second, having N Music available both from NL and Mozart products and the BS 5, I thought might cause problems…..although as I type this it occurs to me I could rename N. Music on the BS5 as well as N. Radio. The BS 5 has pretty much been a wall decoration for years. If connected with Line In I can at least feel like it is functioning part of the system and listen to the music stored on it occasionally if I want to.28 March 2024 at 15:26 #53836 MillemisBRONZE MemberSeems a cool idea – definitely worth trying out.
I guess that the line out is at fixed volume, since it was used for a connection to a tv (integrated setup), where the volume is controlled.
The line-in of the converter has auto sense, if I remember correctly.Looking forward to hear about your findings.
28 March 2024 at 17:18 #53837Razlaw
BRONZE MemberConnecting the BeoSound 5 to the Line In on the converter works fine, with one exception. I can not join Mozart products, only older NL products. What makes it weird is I can join my BS3000 through the converter to Mozart products.
I have Beconnect Core ordered. I am sure if I connect the BS5 to the line in on it, it will all work. I will probably try it although the intended use for the BCC is to use with my BL1s.29 March 2024 at 07:44 #53838 TignumGOLD MemberI have a Beosound 3000 connected by ML but it does not have the newer software chip to function well with a BS5 also connected. Have spent many hours trying to get both to work together well. The BS3000 would need a new chip with Option 5. Second, having N Music available both from NL and Mozart products and the BS 5, I thought might cause problems…..although as I type this it occurs to me I could rename N. Music on the BS5 as well as N. Radio.
Hi Razlaw, my thought was to introduce a second BLC: one for the BS3000 and one for the BS5, both A.Slave. That should allow to ‘filter’ the audio sources you want to have ‘mapped to NL’. And maybe solve your Line In / Mozart problem?
In my (non Mozart) set-up I do the same: I have one BLC feeding BS5 N.MUSIC into NL, and one feeding BS6500 CD into NL. Works well.
Just to be sure! Hope this helps, regards, JohanLocation: Netherlands
29 March 2024 at 11:59 #53839Razlaw
BRONZE MemberWhat sort of control do you have the BS 5 with that option?
29 March 2024 at 13:08 #53840 TignumGOLD MemberHi Razlaw, I can start/stop the BS5, go to next/previous song, instruct a new MOTS seed, access colored favourites, select internet radio stations from preset list. So basic control. In my case the BS5 is in the office/attic where I use it mainly. But in the kitchen/living I often listen to BS5 N.MUSIC and let it MOTS on. I am discovering songs in my own collection that I sofar never really listened carefully to! And I enjoy knowing that my B&O kit is maximally integrated. Regards, Johan
29 March 2024 at 17:12 #53841Razlaw
BRONZE MemberThanks! I will consider another converter. Today I connected the BS5 to line in on a Core. That does allow it to be distributed to all products, Mozart included. Of course can only control it in the room where it is located.
30 March 2024 at 17:52 #53842 carolpaBRONZE MemberHello Razlaw, I would say option 1? The only ‘no speakers connected’ setting is 0, but that is disabling IR remote control. Apart from Option 1, all settings are meant for a MasterLink setup in my view. “The music system has five different Option settings: Option 0. Used when your music system is connected to your video system and no speakers are connected directly to your music system. Option 1. Used when your music system is set up on its own or connected to a video system, when speakers are connected to your music system. Option 2. Used when your music system is set up in one room and connected to a video system set up in another room. Option 5. Used when your music system is set up in a link room which also comprises a Bang & Olufsen television. Option 6. Used when your music system is set up in a link room without a Bang & Olufsen television.” Regards, Johan PS – why not ML connect it to a BLC and enjoy control from other devices?
In my opinion with the proposed use of the BS5, only if the option 0 is chosen will make a difference in a day to day use (of course under the condition there are no other ML device in the same room and/or ML and NL devices listening to IR commands)
4 February 2025 at 16:31 #63400SaltineSurfer
BRONZE MemberHi Razlaw, I can start/stop the BS5, go to next/previous song, instruct a new MOTS seed, access colored favourites, select internet radio stations from preset list. So basic control. In my case the BS5 is in the office/attic where I use it mainly. But in the kitchen/living I often listen to BS5 N.MUSIC and let it MOTS on. I am discovering songs in my own collection that I sofar never really listened carefully to! And I enjoy knowing that my B&O kit is maximally integrated. Regards, Johan
Hi Tigum, do you have your BS5 connected to an NL/ML converter? If so, how are you instructing the MOTS playback? I’ve not yet figured out a way to do this from an NL speaker such as A9 or BS2, via the beoremote 1 or b&o app. Holding down play doesn’t work like it does from masterlink speakers. Many thanks. Rob.
6 February 2025 at 19:09 #63476 TignumGOLD MemberHello Rob, yes I do have the attic’s BS5/BM5 connected to a BLC, it is in A.Slave mode (and it plays some AudioSlave too sometimes!).
While I am listening to BeoSound 5 MOTS music (Chili Peppers) in the kitchen (BeoLab 4000s connected to another BLC – A.Master – with IR eye) I can’t say you can really instruct the playback of MOTS music with a command. You select music on the BS5 (or with a colored Be04 button) and when that queue has ended, the BS5 will continue to play songs that are more of the same. The Red Hot Chili Peppers are apparently more of the same as The Offspring’s L.A.P.D :-). Having said that, when I hold the ‘GO’ button on my older Beo4 for some time, still in the kitchen, the music stops for a moment, to let me know this song is now the ‘seed’. I tested it by playing an album halfway through, and after a long ‘GO’ press the BS5 indeed moves to MOTS and plays similar songs. So you could say that is a way to ‘activate’ MOTS.
I am not sure this all just works because of the BLC behaving as a MasterLink unit. I do not have a true NL speaker to test this with. Maybe Carolpa will chime in?
Regards, Johan
