Home › Forums › Product Discussion & Questions › BeoSound › Beosound 5 Encore N-radio not working
- This topic has 3 replies, 2 voices, and was last updated 4 months, 4 weeks ago by
Jan.
14 April 2026 at 17:23 #123294
JanBRONZE MemberI just bought a Beosound 5 Encore and N-radio isn’t working after connecting it via Wi-Fi. You can solve this via Beocare, who can send a new database to update. But how do I do that? How do I contact Beocare? Or do I need to change some settings in my router?
Groet, Jan.
19 May 2026 at 09:46 #123658Joris Allewijn
BRONZE MemberHi Jan,
Perhaps connecting via LAN cable?
greetz,
Joris
Favourite Product: Beosound 5
20 May 2026 at 17:32 #123674 JanBRONZE MemberThanks for your reply. After I managed to reset it to factory settings, it did work. Using a UTP cable still isn’t working, because I can’t get the table stand off to connect it. Now another problem. It stays in standby mode, and the only way is to disconnect the power again. They remain fun B&O products to work with. Regards, Jan.
31 May 2026 at 21:58 #123783 JanBRONZE MemberIt’s working again. I probably pressed the standby button on the Beo 4 remote for too long out of impatience. The radio works and comes out of standby again after disconnecting the power.
Regards Jan. -
