Home › Forums › General Discussion & Questions › General Discussion & Questions › Beosound 5 Encore
- This topic has 2 replies, 2 voices, and was last updated 3 months, 2 weeks ago by
sanjay.singh thakran.
9 June 2026 at 05:35 #123963
sanjay.singh thakranBRONZE MemberHi ,
I do hope somebody can help me _ I have a Beosound 5 Encore that powers up and goes into the Power Save On/Off – From there to the Select Country but No matter what Country I select it goes back int the Power Save Menu again and again in a Loop. Have tried Reset but the same Issue.
This topic was modified 3 months, 3 weeks ago by
sanjay.singh thakran. Reason: Fixed
You must be logged in to view attached files.28 June 2026 at 18:06 #124263 JanBRONZE MemberHave you managed to put it into service mode to restore the factory settings yet? It requires a specific key combination to do this. Go to **Settings**, press **<** twice, then **GO**; next, select **Maintenance** and press **GO**.
Select **RESET TO FACTORY DEFAULTS** and press **GO**.30 June 2026 at 00:47 #124287 sanjay.singh thakranBRONZE MemberDear Jan , Thankyou so much for your reply. I dismantled the entire Beosound 5 Encore ( Have made a detailed PDF of the process ) I took out the Sandisk 8GB MicroSD card and replaced it with a New Fat32 formatted card and reassembled the BS5e. And it is working absolutely fine. The only problem that I am having with it is that it’s not loading my entire music Collection on my Mac Mini M4. I am using N Music via Firestream DLNA from the App Store ( It recognises the Server on the BS5e. Any suggestions on a Server ). Thankyou for reaching out to me. Warm Regards Sanjay
