Home Forums Product Discussion & Questions BeoMaster Beosound 5 / Beomaster 5 Service Tool
Viewing 12 posts - 1 through 12 (of 12 total)
  • #47089
    Rendboell
    GOLD Member
    Hello all,
    Because of the interest in the Service Tool for BS5 / BM5, I have made the 2.5 GB zip file available for all. Use this link for download:
    https://1drv.ms/u/s!AvyICKrRk1dflLEkQs3K36JxF2p_EQ
    Be patient with the download. It is highly compressed and will take some time to unzip.
    I have attached a short introduction to the content, the B&O Service Manual and updated guides on how to install a new SSD:
    (1) B&O instructions for the Service Tool in the Service Manual for BS5 / BM5. The manual has instructions on how to update the BIOS and replace motherboard, harddisk, B&O master board, etc.
    (2) My guides on how to use the service tool with Hirens Boot CD to use the original B&O clone (Norton Ghost) on a new SSD with correct alignment for SSD drives, including optimizations for SSD drives.
    If you have any questions, please ask in this thread.
    Best regards,
    Jens
    Favourite Product: Beomaster 7000
    Signature: Jens Rendboell
    #47090
    Rendboell
    GOLD Member
    More attached guides:
    (1) How to replace the harddisk / HDD with a SSD drive to get a faster Beosound 5 / Beomaster 5, as well as how to backup the BM5 with Macrium Reflect.
    (2) How to install a 1 TB SSD drive. This is not verified as I have installed a 2 TB SSD, but I think it will work.
    Best regards,
    Jens
    #47091
    Madskp
    GOLD Member
    Just being a little curious I downloaded  the image and are looking at the windows installation at the Norton Ghost image.
    But I haven’t stumbed upon a BS5 program folder or file. Isn’t there one, or is it just burried deep down in the folder structure?
    #47092
    Rendboell
    GOLD Member
    Use ImageUSB 1.5 to copy the service tool to a USB stick.
    The bin file you want to copy to a USB stick is in this folder in the download:
    (1) Beomaster 5 Servicetool\BS5-BM5_ST\BS5-BM5_ST\ServiceTool\bm5 imageusb.bin (3.7 GB)
    Then follow the instructions in chapter 4.4 in the included Service Manual for BS5 / BM5.
    See the “Short introduction to 2 ways of using the service tool” (attached here and also in the download).
    #47093
    Rendboell
    GOLD Member
    If you want to use Hirens Boot CD and Norton Ghost to install a new SSD with correct alignment for SSD drives, then you have to unzip / unpack the 3.7 GB bin file to get the Image700.GHO (1.7 GB).
    Then follow instructions in “(2) Beomaster 5 Clone to SSD (Symantec Ghost)” to install a 1 TB SSD or a 2 TB SSD. (attached here and also in the download).
    #47094
    Stan
    Thanks for posting this.  You are doing God’s work with this :D.
    #47095
    Frog
    GOLD Member
    Nice,
    I had it, then lost it. You have included all the extra components that are useful too!
    note, if trying to access the disk and have the Beomaster 5 on a secure subnet (which is wise as it uses windows XP CE), you need to change the settings in Windows Firewall (on the beomaster 5) in the file and printer sharing to allow access from other subnets.
    #57447
    Shunil Lal
    • Hello , my BM5 hard drive crashed recently and can not be cloned. What are my options as B&O in Singapore do not service the BM5/BS 5 anymore. How do I replace my hard drive. Thank you.
    #65575
    Boonsarm Pooalai
    Hello all,
    Best regards,
    Jens
    I followed the steps you suggested and I was able to turn on the computer, but I have a question:
    1. After installing the program, every time I turn on the computer to enter the system, it freezes on a black screen before entering the program.
    2. Sometimes I can’t boot.
    3. Sometimes I can boot into the program, but after a while the screen goes black and I can’t do anything anymore, so I have to turn off the computer.
    From the above message, what do you think could be the cause? What I’m wondering is whether the power system is like that or not.
    Regards,
    Sammy
    #65613
    Kim Olsen
    Hi my name is kim Olsen, I have beomaster 5 + beosound 5, but right now I have master 5 connected to my TV, my XP has crashed and I am trying to recover, when it restarts after the first phase nothing happens anymore, I can only hear that the HDD is running, it doesn’t sound like anything is wrong as it is just a regular squeak like HDDs do, some solutions would help a lot.
    M.V.H. Kim Olsen.
    #67166
    CharlieWednesday
    GOLD Member
    I know this is an older post now but I wonder if anyone can still help me.  I am a B&O collector but only recently acquired my first Beosound 5. It works, but the software had never been updated, so I have used the Service Tool described here to update it.
    It has worked, but the software has been updated only to version 3.15.02.0659, but Rendboell’s guide indicates it should be updated to version 7.00.00.0569.
    Does anyone know how to update to later versions?
    What I’d really like to do is get Spotify to work, which I know was possible on later versions of the software.  Before anyone warns me, I know that there BS5 works on WinXP and that this is not considered safe for online connection, but I am told there are ways to achieve it via a secure subnet!
    My B&O Icons: No description available No description available No description availableNo description availableNo description availableNo description availableNo description available No description available No description availableNo description availableNo description available
    #67230
    Madskp
    GOLD Member
    I am pretty sure that I used the software package and tools from post #47089 at the top of this page, and I have version 7.00.00.0511
    I don’t remember which version was on my BS5 before I restored it, so I can not be sure if there could be issues if you update from an older version. However I belive that you should be able to restore to an empty drive from that tool, so should be possible.
    Have only been doing the restore once to be sure that all was factory reset, so not much experience with the tool.
