Home › Forums › Product Discussion & Questions › BeoSound › Beosound 4 tuning DAB radio
- This topic has 5 replies, 3 voices, and was last updated 2 years, 9 months ago by
Derek 2112.
4 May 2023 at 02:11 #46299
Derek 2112
BRONZE MemberHey. New to the group I have just received the Beosound 4. With 8000 mk 2 speakers. I am having trouble setting up the DAB radio. Any assistance would be appreciated.
thanks4 May 2023 at 16:15 #46300 Millemis
BRONZE MemberThe user guide found….
….here
might help.Beware – almost all BS4/DAB are DAB only, no DAB+
4 May 2023 at 18:44 #46301Derek 2112
BRONZE MemberTried that it is finding 120 odd stations but I don’t know how to find them or add them.
thanks for your help much appreciated4 May 2023 at 21:12 #46302 GuyModeratorTried that it is finding 120 odd stations but I don’t know how to find them or add them. thanks for your help much appreciated
Have you tried following the advice on page 15 of the manual? As follows:
If DAB tuning results in too many stations for the Program List …
> The available stations appear in the STORE PROGRAM menu.
> Turn the wheel to move between stations.
> Press GO to store a station.
> If the menu is empty, or if you do not want to store more stations, press EXIT to leave the menu.Location: Warwickshire, UK
5 May 2023 at 05:45 #46303 GuyModeratorThe user guide found…. ….here might help. Beware – almost all BS4/DAB are DAB only, no DAB+ MM
Not a problem in UK where the majority of stations are still DAB.
(assuming OP is in UK)
6 May 2023 at 18:48 #46304Derek 2112
BRONZE MemberThank you to everyone for your help. I have got it working.
Thank you
Derek
