Home › Forums › General Discussion & Questions › General Discussion & Questions › Beosound 1 cd scraping
- This topic has 1 reply, 2 voices, and was last updated 7 months, 2 weeks ago by
Guy.
12 August 2025 at 15:43 #68738
LeosgonewildBRONZE MemberI have a Beosound 1 (the original cd player with speaker).
When it plays, the cd is scratching. I can put a piece of thin cardboard between the unit and the cd cover to lift the cover/lid so it doesn’t scratch.
Does anyone know if this is just a screw that needs to be tightened? Or is there any other fix for this?
Is the workbench forum gone btw?
12 August 2025 at 17:52 #68740 GuyModeratorI had had this problem – have a look at my post (and the rest of the thread) here: https://forum.beoworld.org/forums/topic/beosound-1-faulty-cd-player/#post-56558
If you look at the later posts, you can see that the rubber suspension mounts actually have a function in holding the CD unit together. The rubber mounts may have been damaged in the past if the laser has been replaced. If you look at the last post in the thread you will see that I added a couple of small screws to hold my unit together and prevent rubbing.
Your best bet is to carefully dismantle and try to work out the specific problem in your case.
Not sure about the workbench hence will check – I think that the threads were merged into the specific product threads.
