Home Forums Product Discussion & Questions BeoSound Beosound 1 Cd issue
Viewing 13 posts - 1 through 13 (of 13 total)
  • #69722
    Kim Björk
    Hi!
    i got a Beosound 1 (old version)
    the radio and speakers are working well, but it will not open the cd latch, it makes a sound but nothing is happening, would it mean the door mechanism is broken? Or something else inside the cd player, I have yet to disassemble it, figured id ask beforehand so I know if its worth trying to fix.
    #69729
    Guy
    Hi Kim and welcome to Beoworld!
    You really need to disassemble and investigate, but it should be quite straightforward especially if you have the service manual (available on site to Silver/Gold members).  I have three BeoSound 1s and have dismantled all of them to clean and fix various problems with the CD.
    The last one that I took apart had a slight problem with the door mechanism, as you will see if you read my posts in the following thread:  https://forum.beoworld.org/forums/topic/beosound-1-faulty-cd-player/#post-56558
    If you have any further questions come back and ask and maybe provide photos – I can always check the mechanism against one of my working ones.
    My B&O Icons: No description available No description available No description availableNo description availableNo description availableNo description available No description available No description availableNo description availableNo description availableNo description availableNo description availableNo description availableNo description available
    #69732
    Kim Björk
    hi guy!
    ah ok, yes will probably try to take it apart then! seems pretty straight forward and “easy” for a B&O product.
    got quoted 230£ for a cd repair here in sweden or if it was the laser they said 1000£ which I obviously wouldnt pay haha
    if I can i will send a video maybe on what it sounds like when i press the load button
    #69736
    Guy
    That sounds expensive!  My new laser (fitted myself) cost £30!
    Have fun dismantling the BeoSound – it is actually quite straightforward.  And if you break something you can usually find replacement parts such as this:  https://www.ebay.co.uk/itm/186532000399
    #69809
    Kim Björk
    hi again!
    Finally got time to take it apart, and I think I found the issue (at least one for now) and its the small rubber belt that has broken that opens up the hatch. So now is that an easy fix or?
    #69819
    Kim Björk
    Also, would that be the reason the cd wont play as well? as that belt only seems to be for the actual hatch to open?
    #69858
    Guy
    Hopefully, if you can find a replacement belt of the same size – I am not aware of any suppliers so  it may be trial and error!   Unless anyone else knows on the forum.  Otherwise you could buy that replacement clamper from eBay – there is also a new one here:  https://www.ebay.co.uk/itm/166441843810
    I can’t remember if there is a microswitch to tell the system that the clamper is fully down – if there is it should be fairly obvious.  Also the clamper needs t be fully down so that the CD is gripped so that it will turn at the correct speed, otherwise it will not play.
    #69860
    Kim Björk
    Ahh makes sense! I have ordered the cd clamper and will report back when I have installed it , if it works or not!
    thanks!
    #70034
    Kim Björk
    hi! Finally got it to work, took a while to get the cd clamper! but just switched it and it now works!! thanks!
    Gonna enjoy this for a long time now!
    regards Kim
    #70042
    Guy
    Great news – thanks for letting us know.  It’s well worth keeping BS1s in full working order, and it looks very good on your floor stand!
    #70190
    Kim Björk
    hi again!
    noticed a new “issue” and it works eventually after a few tries.
    so since i fixed the clamper it has been working perfectly but yesterday when putting in a new cd it spins for 1 sec and then stops and then spins again but then the hatch opens, I keep reloading and pressing CD and then eventually it start working again.
    Is that the laser slowly giving up or the whole cd mechanism or maybe something else?
    regards, Kim
    #70191
    Guy
    One of my BS1s behaves like that if I haven’t used it for a while.  In fact I just tried playing a CD on my study BS1 and it did the same!
    I think the trick is to use if more often!  The cogs and sliders in the CD mechanism possibly get a bit sticky if unused.  Once it’s running, leave a CD to play all the way through, and exercise the mechanism by moving backwards and forwards through tracks.  Try a few different CDs – very old or very new ones, and of different lengths.
    You can also go into service mode and command the CD laser to focus and move – but I usually leave that until the problem persists for a while.
    #70224
    Kim Björk
    Ah interesting, that makes sense. On account if how dusty mine was etc it probably have been standing stored for a long time!
    i will keep it running everyday!
