Home › Forums › Product Discussion & Questions › BeoGram › Beorgram cd 7000 problem
- This topic has 16 replies, 6 voices, and was last updated 1 year, 9 months ago by
Frank van Rooij.
1 June 2023 at 03:12 #46948
svet
BRONZE MemberHi All,
My Beogram cd 7000 has stopped working. After pressing the Play button the Track sign light up, the disc spins but it fails to read the tracks and it goes off. When the problem appeared I noticed that that after pressing Play the laser was hitting the back of the case, which could be heard. I changed c2103, 2138, 2140 and the laser stopped hitting the back of the case but is still not reading the disc. I can still change c2104 and 2107 but not sure the problem is in the caps. The laser makes the same movement with or without a cd and it is as if it does not understand a disk has been loaded. Is there anything besides the caps l can check? Re:caps. Can I exchange 47u 10v with 47u 25v? I read that the cdm4 of this cd player is very robust and that it rarely fails. Is it worth changing it at this stage or there are other things l should do first? Which variant of cdm 4 would be acceptable for the BG7000? Thank you in advance for your help.1 June 2023 at 15:51 #46949Dillen
ModeratorDid you fit the correct type of capacitor for C2103?
It must be a blue Philips/BC axial. Nothing else can be guaranteed to work.Martin
2 June 2023 at 08:29 #46950svet
BRONZE MemberHi Martin. It is a Nichikon 47u. Can the reason be other then that?
2 June 2023 at 12:03 #46951Dillen
ModeratorThere could be many reasons, but that would be the first on the list.
2 June 2023 at 13:44 #46952Die_Bogener
BRONZE MemberIt is the internal resistor of these blue Philips/BC caps. They are NOT LOW ESR…
… and the player hates LOW ESR for C2103.
Replace all and everything whatever you want, but C2103 must be a blue Philips.
And check for cracks on the connectors.
20 June 2023 at 08:16 #46953svet
BRONZE MemberHi All! I am continuing to have issues with my Beogram cd7000 and have replaced all 6 capacitors from Beoparts. The player have played 1 cd and have switched off, and now it does not read any cds. It shows the same behaviour as when I was replacing the c2103 with non Philips components. Any idea what to check next?
21 June 2023 at 07:53 #46954 filip_kbhBRONZE MemberMaybe a picutre of the board after modification would help.
21 June 2023 at 11:49 #46955svet
BRONZE MemberYes sure. Here it is. I checked the soldering today and turned around the red cap supplied by Beoparts. The player started OK but when I moved it to the amp it did not read the cd anymore.
21 June 2023 at 14:27 #46956Dillen
ModeratorDid you adjust anything?
If you didn’t – DON’T!
If you did – that’s why.Martin
21 June 2023 at 16:52 #46957svet
BRONZE MemberNo adjustments were made.
21 June 2023 at 22:48 #46958 filip_kbhBRONZE MemberC2103 was changed? Looks pretty old and original to me. I changed mine to a blue Philips type 47uf/40V.
22 June 2023 at 07:04 #46959svet
BRONZE MemberYes all capacitors have been changed.
22 June 2023 at 07:35 #46960 filip_kbhBRONZE MemberThe red cap – you mean the polyester cap? It’s not polarised so it doesn’t matter how you put it in. Can we see the back of the board also?
I don’t understand the part about: “The player started OK but when I moved it to the amp it did not read the cd anymore.” Do you mean that it played okay on your work desk when it was assembled? You then physically moved the unit, hooked it up to the amplifier, and then it didn’t work?
23 June 2023 at 06:50 #46961svet
BRONZE MemberMy Beogram cd 7000 still doesn’t read cds after recapping the servo board. I am inclined to replace the laser unit but have the following question. The player is fitted with a cdm-4/56 but I can source a second hand cdm-4/19 which frame seems different. Will I have to exchange the laser itself leaving the original frame and is it easily done?
23 June 2023 at 07:08 #46962 chartzBRONZE MemberHi,
It is very unlikely the CDM itself is faulty. I’ve yet to find a bad CDM4. And I’ve come across quite a few.
Have you checked the voltages as per service manual?
Since you now have the correct caps everywhere, the fault must be around the power supply.
28 June 2023 at 18:06 #46963svet
21 June 2024 at 08:51 #56646Frank van Rooij
BRONZE MemberFirst things first. 99% of alle disk reading problems are caused by a faulty belt. In that case the CD tray is not placed in the exact position. Before recapping anything, change the belt for a new one and make sure the tray is placed correctly.
