Home › Forums › Product Discussion & Questions › BeoRemote › Beoremote one – faulty?
- This topic has 5 replies, 4 voices, and was last updated 3 years, 3 months ago by
NQVHNWI.
3 January 2023 at 07:58 #42062
splud
BRONZE MemberIt suddenly stopped talking to the Theatre, I then did a factory reset and now it will not pair to the Theatre again. I have followed all the instructions. The only thing I haven’t done is a factory reset on the theatre as I just got all the settings sorted, I wish it had a “upload settings” function so that you don’t have to start again.
Is there any thing else the remote can pair with for me to test? ie phone?
3 January 2023 at 09:44 #42063 trackbeo
BRONZE MemberIn the old forum, @riverstyx claimed “yes”:
https://archivedforum2.beoworld.org/forums/p/22895/189582.aspx#189582
3 January 2023 at 10:22 #42064 carolpaBRONZE MemberIt suddenly stopped talking to the Theatre, I then did a factory reset and now it will not pair to the Theatre again. I have followed all the instructions. The only thing I haven’t done is a factory reset on the theatre as I just got all the settings sorted, I wish it had a “upload settings” function so that you don’t have to start again. Is there any thing else the remote can pair with for me to test? ie phone?
did you already “un-pair” the Beoremote One in the settings of the Theatre? and restart from there again?
3 January 2023 at 11:17 #42065splud
BRONZE MemberNo, as the remote just stopped and didn’t think to unpair using the Theatre app.
I have to re-do wires anyway soon, so I’ll do another reset over the weekend on the Theatre and let you guys know how it goes?
3 January 2023 at 11:19 #42066splud
BRONZE MemberHa, the pairing with the phone worked straight away, guess its not faulty then! Here goes the factory reset on the Theatre again……
3 January 2023 at 11:39 #42067NQVHNWI
BRONZE MemberI have commented on the main Theatre thread that there is an issue in comms beteew the BR1, BeoApp and theatre. Too many configurations of the TV/Music Lists in the app crash the BR1 and the BR remote no longer updates. Configure a PUC with the source active (or the 2nd PUC), causes a lock-up.
Hard reset of Theatre seems the only way for now. Reset of the BR does not work, not a soft reboot of the theatre.
