Home › Forums › Product Discussion & Questions › BeoRemote › Beoremote 1 for multiroom IR/BT mix?
- This topic has 1 reply, 2 voices, and was last updated 3 years, 1 month ago by
Millemis.
2 January 2023 at 06:12 #42001
beopaul
BRONZE MemberHi all,
Finally got a new house, and have combined a mix of old & new products successfully into multiroom, controlled by the iPhone B&O app:
- Two Beoplay V1
- Beoplay M5
- Beoplay M3
Currently use the B&O app, and two Beo4 remotes with nav button for the TVs (and use of the Join button). but I’d like to get away from the app for day-to-day operation and use a Beoremote One (BR1) instead, and am wondering how smoothly this works.
Let’s say I want to sit down in from of the V1 TV (an IR-only device) and fire up and listen to a particular B&O Radio station, likely off my M5. Could I do this all strictly from the BR1, and how cumbersome would it be? I’m guessing it’d go something like this:
- Select the M5 on the remote, then scroll to a “favorite”d source,
- Select the TV on the remote, then select “join” under the List button.
Would it be that simple? Thanks for any thoughts on this!
— beopaul
2 January 2023 at 09:51 #42002 MillemisBRONZE MemberWhy not just use the built-in Netradio of the V1’s?
You can map that to the Radio button on the Beo4/navi’s and even choose a station by the number buttons (1-9).For the M3/5 get a BROne/bt and use that there.
if somethings play there, just use the Join function on the Beo4’s for the V1’s….you can move that to the first place in the List for easy access.In my experience it is cumbersome to have to switch all the time between ir and bt products on the BROne/bt for daily use.
