Home Forums Product Discussion & Questions BeoPlay Beoplay M5 as a hub
  • #64209
    boj
    Dear Forum,
    is it possible to Connect a Beolab 7 speaker to a Beoplay M5 via minijack and use the Beoplay speaker as a hub/bridge for the Beolab speaker in terms of Streaming Music?
    Thanks in advance
    Boj
    Millemis
    No!
    #64219
    boj
    Thanks Millemis for a direct answer.
    Guy
    … but both the Essence (pref Mk2) and NL/ML Converter have powerlink outputs and either could act as a ‘hub’, depending on what you are hoping to achieve.
    matador
    … And the Playmaker if you want to stream from a computer.
